Dear Team,
One of the customer is trying to implement 2FA using RSA SecureID for the switch login. Is this possible and does it require only aaa radius configuration on the switch or something else also?
Switch is 3810 running 16.10
it is possible, the 2FA is on RADIUS server
May be need when you connect to set the password and PIN when ask the password (not sure if the switch support ask PIN/challenge )
Yes !
