Wired Intelligent Edge
ArubaOS Switch HPE Splitter Cable Compatibilty
  • 1.  ArubaOS Switch HPE Splitter Cable Compatibilty
    Posted Oct 22, 2020 07:10 AM
    Hi Community,
    Does HPE QSFP+ to SFP+ JG330A or JG331A splitter cable support with the Aruba 5412r zl2 switch
  • 2.  RE: ArubaOS Switch HPE Splitter Cable Compatibilty
    MVP GURU
    Posted Oct 22, 2020 11:06 AM
    Hi! No it doesn't.
    The JG330A is the SKU of a HPE FlexNetwork X240 40G QSFP+ to 4x10G SFP+ Direct Attach Copper Splitter Cable 3 meters long while the JG331A is the SKU of a HPE FlexNetwork X240 40G QSFP+ to 4x10G SFP+ Direct Attach Copper Splitter Cable 5 meters long.
    Both are related to Comware OS based switch series of HPE, they are not related (nor supported by) ArubaOS-Switch OS based switch series.
  • 3.  RE: ArubaOS Switch HPE Splitter Cable Compatibilty
    Posted Oct 22, 2020 11:00 PM
    Thank you... Do I have any supported splitter cable 40G from HPE Synergy to Aruba 5400 zl2 switch without QSFP+ to SFP+ adapter from the synergy side?
  • 4.  RE: ArubaOS Switch HPE Splitter Cable Compatibilty
    MVP EXPERT
    Posted Oct 23, 2020 02:57 AM
    Yes that's possible.
    https://h20195.www2.hpe.com/v2/GetPDF.aspx/c04815258.pdf
    • HPE X140 40G QSFP+ MPO SR4 Transceiver JG325B
    • HPE Multi Fiber Push On to 4 x Lucent Connector 5m Cable K2Q46A
  • 5.  RE: ArubaOS Switch HPE Splitter Cable Compatibilty
    Posted Oct 23, 2020 09:00 AM
    But Why Aruba does not offer any splitting cables.
  • 6.  RE: ArubaOS Switch HPE Splitter Cable Compatibilty
    MVP EXPERT
    Posted Oct 23, 2020 10:07 AM
    The ArubaOS ASICS hardware don't support QSFP+ transceivers with split capability's. What is supported in the ArubaOS-CX and Synergy Virtual Connect F8 modules. It depend on the capability's of the ASICS in the switch.
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00028947en_us
    (page 11)
    "Splitting of QSFP+ and QSFP28 portsQuad-SFP (QSFP+ and QSFP28) ports allow for four channels of lower-bandwidth communication. ArubaOS-CX release 10.05 introduced this feature for select switches and modules. Split port is not availablefor ArubaOS-Switch products."
  • 7.  RE: ArubaOS Switch HPE Splitter Cable Compatibilty
    Posted Oct 22, 2020 11:16 AM
    Greetings!
    Split interfaces (required for splitter DACs and optics to function) are not supported on any AOS-Switch model.
