Developer
ArubaOS switch interface statuschange
  • 1.  ArubaOS switch interface statuschange
    Posted Jul 13, 2023 08:09 AM
    Hi!
    I find the documentation of the APIs for ArubaOS switches (2530, 2930 models...) a bit hard to read.
    Trying to find out if there is any way to get info from the REST-API regarding last status change of a port.
    As in when cable was last unplugged / plugged in.
    Do anyone know if such an endpoint is available ?
  • 2.  RE: ArubaOS switch interface statuschange
    MVP GURU
    Posted Jul 26, 2023 08:49 AM
    Hi Gonz,
    For me, it is not possible with ArubaOS Switch (there is may be some AnyCLI command but you need to parse the result)
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
