Wired Intelligent Edge
last person joined: 9 hours ago
ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only?
  • 1.  ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only?
    MVP GURU
    Posted May 15, 2020 12:41 PM
    Hi! On a VSF (two Aruba 5406R zl2) running on ArubaOS-Switch 16.05.0007 I was always used to see that the show system power-supply detailed CLI command reported details only for VSF Commander's powered PS Modules (PS1 and PS2) lacking totally about PS Modules inserted into the VSF Standby member.
    Example:
    VSF# show system fans
    Fan Information
    VSF-Member  1
      Num  | State       | Failures | Location
    Sys-1  | Fan OK      |   0      | Fan Tray
    Sys-2  | Fan OK      |   0      | Fan Tray
    Sys-3  | Fan OK      |   0      | Fan Tray
    Sys-4  | Fan OK      |   0      | Fan Tray
    Sys-5  | Fan OK      |   0      | PS 1
    Sys-6  | Fan OK      |   0      | PS 2
    0 / 6 Fans in Failure State
    0 / 6 Fans have been in Failure State
    VSF-Member  2
    VSF# show system power-supply detailed
     Status and Counters - Power Supply Detailed Information
      PS Model  Serial     State            Status
      1  J9829A CN6AKxxxxx Powered          AC Power Consumption : 83 Watts
                                            AC MAIN Voltage      : 229 Volts
                                            Power Supplied       : 63 Watts
                                            Power Capacity       : 1100 Watts
                                            Inlet Temp (C/F)     : 32.0C/89.6F
                                            Internal Temp (C/F)  : 50.4C/122.0F
                                            Fan 1 Speed          : 1080 RPM (31%)
                                            Fan 2 Speed          : 1125 RPM (33%)
      2  J9829A IN01Gxxxxx Powered          AC Power Consumption : 85 Watts
                                            AC MAIN Voltage      : 230 Volts
                                            Power Supplied       : 55 Watts
                                            Inlet Temp (C/F)     : 24.1C/75.2F
                                            Internal Temp (C/F)  : 34.4C/93.2F
                                            Fan 1 Speed          : 1600 RPM (47%)
                                            Fan 2 Speed          : 1600 RPM (47%)
       2 /  2 supply bays delivering power.
       Currently supplying 118 W / 2200 W total power.
       Refer to command's help option for field definitions
    Is that a "bug" solved on newer software release or just the designed way the command was built?
    Second question: is it normal to see those differences between PS1 and PS2 (recently changed due to a fault -> PS2 was made in India and newer than PS1 which was made in China)?
    J9829A (Made in China) deployed as PS1
    versus
    J9829A (Made in India) deployed as PS2
    Note that both PS Modules are on the same VSF Commander chassis...and I always looked at the temperature values reported by PS1 (and old PS2 now gone) as normal for the ambient temperature we know there is into the whole rack.
  • 2.  RE: ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only?
    Posted May 21, 2020 06:34 AM
    It is a known issue that "show system power-supply detailed" command gives PS details of teh commander only on a stack/VSF
    Fix is coming in CPE 29 (CR250966)
    show system power-supply (without detailed option) works and that provides some info
  • 3.  RE: ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only?
    MVP GURU
    Posted May 21, 2020 10:57 AM
    Hi! Thanks...it was the very first of my suspects. Out of curiosity what does CPE 29 mean? I know what CR means in this context (CR = Change Request)...but...does CPE 29 mean that next ArubaOS-Switch 16.10 software version incorporating the fix will be released during week 29th 2020?
  • 4.  RE: ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only?
    Posted May 22, 2020 11:36 AM
    As far as I know CPE means COLLEGES WITH POTENTIAL FOR EXCELLENCE.
    CPE29
    It is just numerically incrementing last release was CPE 28
    Release CPE29: Expected in early-mid June (Please add a week or two buffer for communicating to customer during this Covid-19 pandemic)
  • 5.  RE: ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only?
    MVP GURU
    Posted May 22, 2020 11:50 AM
    Gosh, mine was a joke!
    I'm pretty sure that CPE is the acronym of Current Product Engineering (referred to a Software branch)...so, OK...it's CPE 29th...and thus the next stage will be the GA release, expected to be available in early-mid June 2020.
    That's look good!
    Thanks! Definitely, it's time for me to plan an update to that VSF.
  • 6.  RE: ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only?
    MVP GURU
    Posted Jul 01, 2020 04:12 AM
    CR_0000250966 "The switch fails to display the power supply details" Fixed on 16.10.0009 available since today July, 1st 2020.
