ArubaOS switches & ClearPass Radius & Aruba Central
This thread has been viewed 21 times
  • 1.  ArubaOS switches & ClearPass Radius & Aruba Central
    Posted Jan 28, 2022 11:50 AM
    Hi folks,
    Not sure where to post this since it touches all of the above but basically I noticed when adding a radius server in Aruba Central for an ArubaOS switch it gives you the option to say where the radius server ClearPass - see screenshot.
    What affect does this have on the switch? and if not on the switch what's the benefit of defining this in Central?
    The documentation did not provide any details.
    Thank you!
    MG
    Cheers!
    MG
  • 2.  RE: ArubaOS switches & ClearPass Radius & Aruba Central
    MVP GURU
    Posted Jan 28, 2022 11:57 AM
    From what I remember, you would need to enable this if you are using downloadable user roles. See here for the documentation on this piece: Configuring RADIUS Server Settings on AOS-S Switches
    And also here for explanation on the DUR side of that option: Configuring Downloadable User Role
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: ArubaOS switches & ClearPass Radius & Aruba Central
    MVP EXPERT
    Posted Jan 29, 2022 04:13 AM
    Hi
    If you’re configuring a 2940 switch , flagging the
    radius service as being clearpass allows you to set up device fingerprinting o the switch. Defining server as clearpass tells the switch which server(s) to upload discovered data to
    Might be a reason
    Rgds
    A
    Sent from my iPhone
