Wired Intelligent Edge
ArubaOS Switches SSL certificates and Python
Jump to Best Answer
  • 1.  ArubaOS Switches SSL certificates and Python
    Posted 21 days ago
    I have started digging into the REST API of our access switches (2930F)
    I'm using Python to do so.
    Its all fine in my LAB where i do not use https "web-management ssl"
    But i do not want to deploy anything in production over HTTP.
    How do you guys handle certificates on your switches.
    Do you tell python to ignore the cert error?
    Or do you follow the process of:
    1. Import ROOT cert from PKI
    2. Generate CSR
    3. Sign CSR
    4. Import signed cert.
    I see above being quite time consuming as we have 100+ switches.
  • 2.  RE: ArubaOS Switches SSL certificates and Python
    Posted 20 days ago
    You can use EST - Enrollment over Secure Transport server to deploy certificates in enterprise network AOS switches. More details of the same are present in
    https://techhub.hpe.com/eginfolib/Aruba/16.09/5200-5903/index.html#GUID-04606DF3-F151-4182-87AA-E8D3E3207A4C.html
    Shobana
    Aruba
  • 3.  RE: ArubaOS Switches SSL certificates and Python
    Posted 20 days ago
    Will for sure look into that.
    We have a Microsoft PKI infrastructure, does not seem its a service MS offers.
  • 4.  RE: ArubaOS Switches SSL certificates and Python
    Posted 11 days ago
    Dear i am having issue with ArubaOS Local Web GUI on 1930 Aruba Switch
    please share 1930 Switch Hardening guide
  • 5.  RE: ArubaOS Switches SSL certificates and Python
    Posted 11 days ago
    SSL can't import certificate - conversion of input to certificate failed. also getting this error
  • 6.  RE: ArubaOS Switches SSL certificates and Python
    Posted 8 days ago
    The Aruba Instant ON 1930 switch is a completely different type of switch. Procedure above is for 2930F AOS-Switches.
    Please ask your question on the Aruba Instant ON forum for a better coverage/audience.
