Wired Intelligent Edge
ArubaOS Switches SSL certificates and Python
Jump to Best Answer
  • 1.  ArubaOS Switches SSL certificates and Python
    Posted Jul 26, 2022 03:00 PM
    I have started digging into the REST API of our access switches (2930F)
    I'm using Python to do so.
    Its all fine in my LAB where i do not use https "web-management ssl"
    But i do not want to deploy anything in production over HTTP.
    How do you guys handle certificates on your switches.
    Do you tell python to ignore the cert error?
    Or do you follow the process of:
    1. Import ROOT cert from PKI
    2. Generate CSR
    3. Sign CSR
    4. Import signed cert.
    I see above being quite time consuming as we have 100+ switches.
  • 2.  RE: ArubaOS Switches SSL certificates and Python
    Posted Jul 27, 2022 04:47 AM
    You can use EST - Enrollment over Secure Transport server to deploy certificates in enterprise network AOS switches. More details of the same are present in
    https://techhub.hpe.com/eginfolib/Aruba/16.09/5200-5903/index.html#GUID-04606DF3-F151-4182-87AA-E8D3E3207A4C.html
    Shobana
    Aruba
  • 3.  RE: ArubaOS Switches SSL certificates and Python
    Posted Jul 27, 2022 06:04 AM
    Will for sure look into that.
    We have a Microsoft PKI infrastructure, does not seem its a service MS offers.
  • 4.  RE: ArubaOS Switches SSL certificates and Python
    Posted Aug 05, 2022 07:13 AM
    Dear i am having issue with ArubaOS Local Web GUI on 1930 Aruba Switch
    please share 1930 Switch Hardening guide
  • 5.  RE: ArubaOS Switches SSL certificates and Python
    Posted Aug 05, 2022 07:15 AM
    SSL can't import certificate - conversion of input to certificate failed. also getting this error
  • 6.  RE: ArubaOS Switches SSL certificates and Python
    Posted Aug 08, 2022 09:11 AM
    The Aruba Instant ON 1930 switch is a completely different type of switch. Procedure above is for 2930F AOS-Switches.
    Please ask your question on the Aruba Instant ON forum for a better coverage/audience.
