  • 1.  ArubaOS upgrade from 8.1 to 8.11
    Posted Jul 24, 2024 12:39 PM
    Dear Experts,
    I tried looking in the release notes but couldnt find any proper upgrade path from 8.1 to 8.11. What i have understood is, we need to upgrade from 8.1>8.3>8.11? Is this correct?
  • 2.  RE: ArubaOS upgrade from 8.1 to 8.11
    Posted Jul 25, 2024 03:57 AM
    Following the book, you would keep the Mobility Conductor (MCR) within 3 versions from the MD. I probably would do 8.1 -> 8.3 -> 8.6 -> 8.10 -> 8.11 to be safe, but if you have time and can take a risk, you could upgrade 8.1 -> 8.11 directly to save time, especially if you just have controllers and not MCR. If this is a critical deployment, you could ask TAC to have a look at your upgrade plan, and possibly to be standby when you perform the upgrade.
    In general, I've not really seen many upgrade issues with AOS, but the bigger steps you make, the fewer people have done it before.
  • 3.  RE: ArubaOS upgrade from 8.1 to 8.11
    Posted Jul 25, 2024 04:01 AM
    Dear Herman,
    Thank you for coming in. These are standalone controllers. So if i understood correctly, we can directly upgrade to 8.11 from 8.1 because in release notes, upgrade from 8.3 is the lowest version mentioned.
  • 4.  RE: ArubaOS upgrade from 8.1 to 8.11
    Posted Jul 25, 2024 05:34 AM
    I don't see a limitation, just about free flash space. If you have at least the amount of space free as referenced for 8.3, I would expect that a direct upgrade works; but 8.3 as intermediate would not hurt. Make (flash) backups and other precautions you would do for any upgrade. If unsure, get TAC involved.
  • 5.  RE: ArubaOS upgrade from 8.1 to 8.11
    Posted Jul 25, 2024 02:11 PM
    Hi.
    As Herman mentioned, check the free flash space and have some more than recommended. This is very important for controllers that were running for a very long time. Clear logs, dumps and other files from flash. Have a serial console connected during upgrade to see, what it is happening. Check if all your APs are supported on the version you want to go. If you have AP2xx in your configuration (seems likely) check if they are still supported. 8.10 is LSR release that support majority of older APs. 8.11 drop support for 2xx series.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
