ArubaOS vs Instant versions
This thread has been viewed 39 times
  • 1.  ArubaOS vs Instant versions
    Posted Jun 14, 2018 02:50 AM
    Hello. I'm new in Aruba community.
    In my company we use Aruba AP 207 for wi-fi implementation.
    I wanted to know if arubaOS is something different from Instant, because I searched for updates on firmwares and I found different versions for each one.
    Thank you.
  • 2.  RE: ArubaOS vs Instant versions
    Posted Jun 14, 2018 06:36 AM
    For ArubaOS you also need a controller and licenses.
    Most common features are available on both ArubaOS and instant.
    If you don’t have a controller use instant, if you have a controller use ArubaOS
  • 3.  RE: ArubaOS vs Instant versions
    Posted Jun 15, 2018 06:49 AM
    aruba os is the os used for the controller.
    The instant version is the os used by APs that are kept in standalone mode.
    Normally, the instant AP can also work as a campus AP, but in apboot mode, you can download os from the controller using the command bootcmd tftpboot or convert from gui to campus AP.
  • 4.  RE: ArubaOS vs Instant versions
    Posted Jun 15, 2018 06:54 AM
    update.
    All new model AP's will be unified AP's and can function as CAP, IAP or RAP.
