Tested Version:
- Standalone VMC ArubaOS version 8.5.0.3
- Scrutinizer_VA_18.16
These two devices are installed in VMWare ESXI within the same subnet. I have one AP and one client connected to my controller to generate client traffic.
1. Install Scrutinizer as shown in this guide https://docs.plixer.com/projects/scrutinizer/en/latest/deployment_guide/scrutinizer_deployment_guide.html
then configure system ip address, DNS, NTP, etc.
2. I have working setup for VMC controller with one AP and one client connected. Configure IPFIX: Configuration>Services>External Services>IPFIX.
(VMC1) [mynode] #show ip-flow-export-profile
IP Flow Collector Profile
Parameter Value
State Enabled
Interval (minutes) to upload all active sessions 1
Interval (minutes) to upload cache snapshot 1
Interval (minutes) to upload IPFIX template 1
Transport Protocol for collector connection udp
IPFIX Collector IP address 192.168.1.25
Transport Port for collector connection 4739
Flow Cache size in entries 15000
Observation Domain 0
Wireless Export Enabled
![IPFIX-VMC.JPG IPFIX-VMC.JPG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/fdf5ac28547c433e90da71e4b1f73da2_0cae9013c0ba4147acd5fb7ad60c67a9)
Change the settings here to 1 minute for testing to get the data quickly.
You can verify collector configuration
(VMC1) [mynode] #show ip-flow-export collector 192.168.1.25
Observation Domain: 3232235837 (Controller IP)
Collector IP 192.168.1.25, protocol udp, port 4739, enabled (wireless-export), connected
Upload template every 1 minute(s), upload all sessions every 1 minute(s), upload flow cache snapshot every 1 minute(s)
UNIFLOW, flow cache size 15000, flows exported 4940, next sequence 4940, 413 packets, 190616 bytes
Last template send: 03:40:38 11-06-2019, last dispatch: 03:40:38 11-06-2019, 71 flows(64 ID-300, 7 ID-301, 0 ID-302)
0 Connect errors, 0 connection resets, 0 send errors, 0 flows dropped, 0 blocked sends
3. Wait after one minute and you can see the data in scrutinizer.
![scrutinizer.JPG scrutinizer.JPG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/fdf5ac28547c433e90da71e4b1f73da2_843769f3d1d84744adc175a9b3bac91f)
