last person joined: 7 hours ago
ArubaOS8 Mobility-Master - Partial vs Full Config
This thread has been viewed 191 times
  • 1.  ArubaOS8 Mobility-Master - Partial vs Full Config
    Posted Nov 15, 2018 11:51 AM
    At what point does the "full config" of managed devices get updated or written to the mobility master? While troubleshooting an issue last week with CCM, noticed the full-folder had the configuration files along with Config-ID - and the controllers IDs were older. This ended up causing an issue during the L3 MM fail-over where the managed devices reverted back to older versions of our validuser acl. TAC case is currently open.
    n=md=Campus=<local-controller-1-395>.cfg
    n=md=Campus=<local-controller-2-302>.cfg
    n=md=Campus-405.cfg
  • 2.  RE: ArubaOS8 Mobility-Master - Partial vs Full Config
    Posted Nov 15, 2018 12:43 PM
    All you had to say is L3 MM failover.  I am not sure that is supported as of yet.
    EDIT: Yes it is supported.
  • 3.  RE: ArubaOS8 Mobility-Master - Partial vs Full Config
    Posted Nov 21, 2018 12:08 AM
    L3 MM failover is supported. If a change was made between the replication window of the L3 MMs (this is configured or configurable) then the two MMs could have different config IDs.
    Anytime the MM makes a config change and then a write mem is ussued, then a new config ID is generated and the diff pushed to the controllers. I don't know if there is a set specific window where the CFGs are merged. So long as the config ID is the same for the active MM and the MDs, that's what matters. If your L3 MMs are not syncing correctly, or the sync is disabled, please open a TAC case and have them check it. But the smallest window for L3 MM sync is two hours. SO there IS a rare chance that if you have an active MM and just pushed a config change and then lost the MM, that the MDs would revert to the L3 MM after 15min and may pull an older ocnfig.
  • 4.  RE: ArubaOS8 Mobility-Master - Partial vs Full Config
    Posted Nov 27, 2018 11:18 AM
    @cjoseph, funny thing. You helped answer one of the the 3 issues we ran into during the L3 MM Fail-Over when you prompted that support question. :-) I went looking for one of the original L3 MM posts for support verification, and remembered the lack of "configuration ability" from the standby L3 MM was by design - https://community.arubanetworks.com/t5/Wireless-Access/Layer-3-Redundancy-for-Mobility-Master-on-8-2/m-p/313229#M75784 -- from jhoward - "There will not be any configuration abaility (ability to manage configurations of the MCs) *unless* you manually promote the Standby MM to Primary. This is to prevent split brain issues and you would only promote the standby if you know the primary MM is down for good or for awhile."
    @jhoward, thanks for the additional information (and the other post about lack of configuration ability from a Standby L3 MM Failover unless it's manually promoted to Primary). I'm continuing to work with TAC on the issue - a bit more info I should have included - I saw this behavior about 8 weeks ago (thought it had been a fluke):
    I was clearing up a "config commit error" related to a syslog server setting on the MDs:
    1. Removed errored out syslog config setting
    2. Issued a "ccm-debug full-config-sync" to perform a full sync per another post
    3. Sync completed successfully after performing "show switches"
    4. Started receiving "connectivity issues" - upon reviewing the configuration of the "validuser" acl - discovered the "any any any deny" had moved up to the top.
    What it almost looked like happened in both cases. When a "Full Sync" occurred, it loaded a version of the "validuser" acl from the "full folder", but none of the partial configs since then (based on obervation -> I gave TAC serveral screenshots of my observation from the flashbackups) - and referenced if this could be related to Defect 182049 - which is resolved in ArubaOS 8.2.2.2.
    Sorry for all the complex observations. :-) I am still working with TAC.
    While on topic - how does one promote a Standby L3 MM to a Primary? I've asked TAC about this for future reference, but haven't heard back yet.
  • 5.  RE: ArubaOS8 Mobility-Master - Partial vs Full Config
    Posted May 31, 2019 02:05 PM
    Updating my original post even though resolved several months ago. Engineering identified our issue as 177162 - Resolved in 8.3.0.2 - https://www.arubanetworks.com/techdocs/ArubaOS/8.3.x.x/Content/ReleaseNotes/ResolvedIssues/Resolved8.3.0.x/Resolved8.3.0.x.htm
  • 6.  RE: ArubaOS8 Mobility-Master - Partial vs Full Config
    Posted May 31, 2019 05:20 PM
    One other thing to remember is the synchronization of the MM databases. L2 synchronization is every 60 minutes between the MMs by default and L3 synchronization is every 120 minutes to the L3 redundant MM(s), as shown in the output below.
    (MM2) [mynode] #show database synchronize
    Last L2 synchronization time: Fri May 31 17:04:22 2019
    Last L3 synchronization time: Fri May 31 17:04:23 2019
    To Master Switch at 10.254.1.101: succeeded
    To Secondary Master Switch at 192.168.240.100: succeeded
    WMS Database backup file size: 47118 bytes
    Upgrademgr Database backup file size: 3392 bytes
    Cluster upgrademgr Database backup file size: 3885 bytes
    Local User Database backup file size: 35912 bytes
    Global AP Database backup file size: 24270 bytes
    IAP Database backup file size: 3769 bytes
    Airgroup Database backup file size: 3069 bytes
    License Database backup file size: 3248 bytes
    CPSec Database backup file size: 3224 bytes
    Bocmgr Database backup file size: 6047 bytes
    L2 Synchronization took 3 second
    L3 Synchronization took less than one second
    199 L2 synchronization attempted
    0 L2 synchronization have failed
    101 L3 synchronization attempted
    2 L3 synchronization have failed
    L2 Periodic synchronization is enabled and runs every 60 minutes
    L3 Periodic synchronization is enabled and runs every 120 minutes
    Synchronization doesn't include Captive Portal Custom data
    Airmatch database gets synchronized periodically. Last synchronization time : 2019-05-31 16:48:29
    I hope this is helpful,
  • 7.  RE: ArubaOS8 Mobility-Master - Partial vs Full Config
    Posted May 31, 2019 06:13 PM
    I forgot to mention you can easily force a synchronization.
    To see the status, use the following command
    To force a synchronization (of both L2 and L3 MMs) use the following command from the MM that is the VRRP master
    database-synchronize
    The following output shows the synchronization status, then performs a synchronization, and then shows the status again.
    Last L2 synchronization time: Fri May 31 18:04:28 2019
    WMS Database backup file size: 45968 bytes
    Local User Database backup file size: 35910 bytes
    License Database backup file size: 5599 bytes
    L2 Synchronization took 4 second
    200 L2 synchronization attempted
    Airmatch database gets synchronized periodically. Last synchronization time : 2019-05-31 17:49:35
    (MM2) [mynode] #database-synchronize
    Database synchronize has been initiated.
    Please check the status using 'show database synchronize' command.
    Last L2 manual synchronization time: Fri May 31 18:09:36 2019
    Last L3 manual synchronization time: Fri May 31 18:09:37 2019
    WMS Database backup file size: 46124 bytes
    L3 Synchronization took 1 second
    201 L2 synchronization attempted
    102 L3 synchronization attempted
