ArubaOS8 Standalone Controller / mgmt ip unreachable if the production interface is down
  • 1.  ArubaOS8 Standalone Controller / mgmt ip unreachable if the production interface is down
    Posted May 24, 2022 07:35 AM
    I have a controler configured on standalone mode, with a mgmt interface.
    When I disable the production interface of my controller, I can join the mgmt interface only when the source IP is on the same subnet as the mgmt subnet.
    Also , i noticed that the bellow  cmd is not working on standalone platform
     [mynode] (config) #ip default-gateway mgmt 10.34.97.250
    Command supported only on VMC/MM platforms
    How the controller work in this case ? it send ARP request event if the destination IP is not on the same subnet ?
    Do you have any solution  ?
    Thank you
    KHERRAB Abdelkader
  • 2.  RE: ArubaOS8 Standalone Controller / mgmt ip unreachable if the production interface is down
    Posted May 24, 2022 09:12 AM
    You cannot route traffic through a management interface.  You would typically be on a jump box on the same subnet as the management interface, plugged into the management interface.  That is the design.
