ArubaPhyType dot11n support
  • 1.  ArubaPhyType dot11n support
    Posted Jul 02, 2014 06:02 PM
     ArubaPhyType defined in aruba-tc.mib does not include dot11n type. The what ArubaPhyType  values do 802.11n APs take?
  • 2.  RE: ArubaPhyType dot11n support
    Posted Jul 05, 2014 11:22 PM
    I am guessing this is an old MIB and there is probably a replacement to this in another.
    My 11n and 11ac APs have dot11a(1) for the 5GHz radio and dot11g(3) for the 2.4GHz
  • 3.  RE: ArubaPhyType dot11n support
    Posted Jul 05, 2014 11:27 PM
    My 11n and 11ac APs have dot11a(1) for the 5GHz radio anddot11g(3)   for the 2.4GHz
  • 4.  RE: ArubaPhyType dot11n support
    Posted Jul 07, 2014 06:31 AM
    Thanks. Does anyone know about the replacement MIB?
  • 5.  RE: ArubaPhyType dot11n support
    Posted Jul 07, 2014 07:01 AM
    ssmith,
    The current Mibs for each software release are in the downloads folder for each release.
  • 6.  RE: ArubaPhyType dot11n support
    Posted Jul 07, 2014 03:59 PM
    Thanks. What is the name of the replacement MIB for aruba-tc.mib?
  • 7.  RE: ArubaPhyType dot11n support
    Posted Jul 07, 2014 06:50 PM
    Did you download the Mibs from the software folder for the Verson of ArubaOS you are running?
  • 8.  RE: ArubaPhyType dot11n support
    Posted Jul 09, 2014 06:52 PM
    The MIBs was downloaded from www.oidview.com. Can you please post the link for downloading the MIBSs for Aruba OS 3.1? Thanks.
  • 9.  RE: ArubaPhyType dot11n support
    Posted Jul 09, 2014 07:09 PM
    You need an Aruba Support Site login to do this:
    Go to support.arubanetworks.com and Login.  Go to Download Software> ArubaOS> General Availability> Archives and find your version of code.  The Mibs will be in the same folder.
