Wired Intelligent Edge
ArubaVPN with MAS and alerting when the tunnel is down
  • 1.  ArubaVPN with MAS and alerting when the tunnel is down
    Posted Oct 22, 2015 01:16 PM
    Maybe i simply missed this somewhere but how can I be alerted when a VPN tunnel between a MAS and a controller is offline using Airwave?
    I will be relying on this alert to proactively investigate issues.
  • 2.  RE: ArubaVPN with MAS and alerting when the tunnel is down
    Posted Oct 22, 2015 01:18 PM
    Do you have syslog being sent to AirWave? You can create an alert trigger that keys off the relevant log text.
    Tim
  • 3.  RE: ArubaVPN with MAS and alerting when the tunnel is down
    Posted Oct 22, 2015 01:27 PM
    Not currently since Airwave does not sit behind the tunnel, it will have to go to a public IP for that. Shouldn’t be an issue. Simply send logging to <public_ip>
    Add the switch using port forwarding rules from the public side or maybe I can key off the controller logs?
    Airwave is at our DC, MAS is at the dealership and WLC is at customers DC.
  • 4.  RE: ArubaVPN with MAS and alerting when the tunnel is down
    Posted Dec 17, 2015 05:55 PM
    So I got this to work finally.
    the MAS generates the following syslog message
    Dec 17 17:43:29 :217002:  <WARN> |l3m|  Vlan interface _aruba-vpn link state down
    I then made sure my MAS was sending syslog message to my Airwave by typing
    conf t
    logging <Airwave_IP>
    exit
    wr me
    On Airwave, in System -> Syslog & traps, if I filter by my device or just search for
    _aruba-vpn
     You will see the following:
    At this point you create a trigger that matches the device event with the contents of the syslog message and send an email to yourself.
    You then get the alert in Airwave
    You will then receive the email as well:
    Device Event: Event Contents matches Vlan interface _aruba-vpn link state down and Event Type is Syslog
    Severity: Critical
    Time: Thu Dec 17 17:45:17 2015
    Notes: VPN DOWN!!!!
    Device: HON-ON-MAR-00001-SW1 - https://wlan-aw-1.c6.dv/ap_monitoring?id=15421
    Group: Canada
    Folder: Top > Canada > HON-ON-MAR-00001 > Switch
    Alert Time: 2015-12-17T17:45:16-05:00
    Message: Dec 17 17:43:29 HON-ON-MAR-00001-SW1:PRI-0 l3m[1567]: <217002> <WARN> |l3m|  Vlan interface _aruba-vpn link state down
    Bingo Bango
