ASE
  • 1.  ASE
    Posted Dec 16, 2013 10:46 AM
    I've been getting quite a few PM messages and wanted to share this....
    For those of you that haven't seen it or are getting ready to deploy clearpass there is a new tool out there for partners and customers with an support account to help you setup up certain scenarios. IAP W/Single SSID, CPPM and MAS, and just recently they added the CPPM and WLC basic setup. This will kick out a config that you will be able to put on either your Controller, IAP or switch
    https://ase.arubanetworks.com/
  • 2.  RE: ASE
    Posted Mar 23, 2014 11:44 PM
    New Feature Added to ASE.
     What's new in Beta v3.1? More Details
    • Airheads Enthusiast user accounts now have full access to ASE.  A support account is no longer required.
    • New Features
      • Version Compatibility Feedback - Users can submit and view feedback for a solution's compatibility with particular product versions.  If you have deployed the configuration built from a solution, please submit which versions it worked on or didn't work on.  Version votes highlighted in green or red have been verified by an Aruba employee that these set of products do or do not work, respectively.
      • CPPM + CPG Config Support - Solutions can now build configuration in CPPM's XML format or CPG's custom .dat format.  Downloadable files are provided and can then be imported into CPPM or CPG.
      • GUI Live Preview - The live preview can now toggle between the existing CLI based mode and a new mode that shows GUI screenshots from the product you are configuring.  The screenshots give you a web path so you know how to navigate to this configuration section in the product GUI.
    • New and/or Updated Solutions
      • AP Fast Failover - Leverage the new AP Fast Failover feature introduced in Aruba OS (AOS) 6.3, which minimizes the AP failover time in the event of a controller failure.
      • Wireless SSID - Solution has been updated to optionally configure a High Density network in an open office.
      • Captive Portal - Internal / External (ClearPass) - Solution has been updated to take advantage of the new CPPM + CPG support. Go through the solution to create ClearPass XML and .dat import files in addition to the AOS config for an end-to-end ClearPass Captive Portal config.
