assign multiple vlans from clearpass using IAP
  • 1.  assign multiple vlans from clearpass using IAP
    Posted Feb 11, 2020 04:45 AM
    Dears,
    i need to assign multiple vlans from clearpass on the same SSID according to user credentials on AD using IAP
  • 2.  RE: assign multiple vlans from clearpass using IAP
    Posted Feb 11, 2020 11:45 AM
    Why? You know you'll need to trunk all these VLANs to each IAP right?
    You have a highly configurable role based access system. Unless you have a specific use case that specifies you must use VLAN separation I would assign roles (with appropriate firewall policies if necessary) rather than VLANs.
  • 3.  RE: assign multiple vlans from clearpass using IAP
    Posted Feb 12, 2020 03:37 PM
    As jrwhitehead mentions, I would probably go back to the drawing board for this one. Although it is completely possible if you trunk the VLAN to all the IAPs.
    Configure profiles using the Aruba-User-Vlan (2) attribute, create a policy matching your user credentials to the desired profiles and match the flow in a service.
  • 4.  RE: assign multiple vlans from clearpass using IAP
    Posted Feb 19, 2020 06:59 AM
    Make sure you trunk all the necessary VLANs to the IAP and in ClearPass use the Aruba-User-VLAN attribute to return the VLAN as an enforcement profile based a on the AD membership condition
    Sent from Mail for Windows 10
  • 5.  RE: assign multiple vlans from clearpass using IAP
    Posted Feb 25, 2020 09:05 AM
    thank you so much ^_^ it works
