Assigned a tagged Management VLAN which blocks untagged access
  • 1.  Assigned a tagged Management VLAN which blocks untagged access
    Posted Sep 11, 2020 01:48 AM
    Hi.
    I'm trying to assign a tagged management VLAN to an AP using
    uplink-vlan 100
    If the Instant AP connects to port that doesn't have this VLAN tagged on it, it reboots a few times and then starts to use the untagged VLAN.
    Is there a way to prevent it from every using the untagged VLAN?
    Thanks.
  • 2.  RE: Assigned a tagged Management VLAN which blocks untagged access
    Posted Sep 11, 2020 07:41 AM
    It's very much not recommended to use tagged management VLANs. Use the native VLAN instead, which on the switch port can be configured on a specific vlan as trunk native VLAN or untagged VLAN.
    In the case you really can't get away from using a tagged management VLAN, I would work closely together with Aruba Support if you have issues like these.
    Or do others have different experiences?
  • 3.  RE: Assigned a tagged Management VLAN which blocks untagged access
    Posted Sep 13, 2020 08:12 PM
    Thank you for responding.
    What is the reason that tagged VLANs are not recommend for the Management VLAN?
  • 4.  RE: Assigned a tagged Management VLAN which blocks untagged access
    Posted Sep 14, 2020 04:41 AM
    Not fully sure about all the backgrounds, but it may have to do with the added complexity, pre-provisioning needed, and the default setup is to use the untagged so that is what most of the people in the world are running. I'd only implement this if you can't configure your edge switches to have the management VLAN untagged.
    Best-practice is to stay with the defaults unless you have a good reason to deviate from that.
    What would be the reason to have your management tagged?
  • 5.  RE: Assigned a tagged Management VLAN which blocks untagged access
    Posted Jan 17, 2021 10:40 AM
    Dear Herman Robers.
    all most I have the same issue, but in my case, I'm trying to use VLAN for IAP MGMT (NATIVE VLAN) and an IP address from a different subnet for Virtual controller IP (Allowed on the trunk).
    I'm not able to access IAP through VIP, changed the Virtual controller IP settings under the system option, but the same result.
    in brief i need to use VLAN for IAP mgmt and different VLAN for VIP.
    mohammad al-alami
  • 6.  RE: Assigned a tagged Management VLAN which blocks untagged access
    Posted Jan 18, 2021 03:49 AM
    The Virtual Controller IP needs to be in the same untagged (management) network as your APs.
    Only wireless clients should be placed in tagged VLANs at the AP.
