Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
Assigning virtual IP for virtual controller in Aruba Central
  • 1.  Assigning virtual IP for virtual controller in Aruba Central
    MVP
    Posted Dec 22, 2022 01:24 AM
    Where can I find the option to put virtual IP in IAP controlled by Aruba Central? I need to put virtual IP to configure in the radius server for 802.1x authentication setup. I cannot find this option in the Central.
  • 2.  RE: Assigning virtual IP for virtual controller in Aruba Central
    Posted Dec 22, 2022 03:10 AM
    you need to go the group you have for your APs, then Security-> Authentication servers
  • 3.  RE: Assigning virtual IP for virtual controller in Aruba Central
    MVP
    Posted Dec 22, 2022 06:20 AM
    I am not talking about the authentication server in the IAP. I am talking about the virtual controller IP that has to be provided in the radius server. Where can I configure virtual IP for the instant AP cluster.
  • 4.  RE: Assigning virtual IP for virtual controller in Aruba Central
    Posted Dec 22, 2022 09:44 AM
    Go in your Configuration Group, then Devices, Configuration, System, under Virtual Controller you can edit the Virtual Controller IP:
    If you scroll further down you can configure the Dynamic RADIUS Proxy setting.
