Go in your Configuration Group, then Devices, Configuration, System, under Virtual Controller you can edit the Virtual Controller IP:
If you scroll further down you can configure the Dynamic RADIUS Proxy setting.
Original Message:
Sent: Dec 22, 2022 01:23 AM
Subject: Assigning virtual IP for virtual controller in Aruba Central
Where can I find the option to put virtual IP in IAP controlled by Aruba Central? I need to put virtual IP to configure in the radius server for 802.1x authentication setup. I cannot find this option in the Central.
