Assigning wireless users to different VLANS based on Radius authentication
  • 1.  Assigning wireless users to different VLANS based on Radius authentication
    Posted Apr 18, 2012 02:02 PM
    (Re-edited)
    Using a IAS as a Radius back-end and returning the VLAN in which the user belongs to based, for example, group membership works fine - But I've only tried this without terminating it on the controller.
    Besides having a certificate on the controller - Does this basically work without configuration changes if I terminate the Radius authentication on the wireless controller instead? A bit unsure on this point - Are the attributes necessary still get returned to the controller - in this case, the VLAN the user should end up in?
    Regards
    Tommy
  • 2.  RE: Assigning wireless users to different VLANS based on Radius authentication
    Posted Apr 19, 2012 06:32 AM
    I can say that it works for me when the authentication is terminated on the controller.
