Associated client not showing in Clients list
  • 1.  Associated client not showing in Clients list
    Posted Nov 14, 2014 04:58 AM
    I have a medical network setup that is used for Draeger Infinity M300 device.
    They are pretty basic in terms of their wireless functionality.
    I have attached a screenshot from the Aruba Controller stating the client is associated and authenticated yet it does not show in the connected clients list.
    I wanted to know what would cause that behaviour. At the moment its a case of its not you its us and vice versa.
  • 2.  RE: Associated client not showing in Clients list
    Posted Nov 14, 2014 07:02 PM
    A client would not show up in the user table if it does not get an ip address.  I would configure debugging for that client:
    config t
    logging level debugging user-debug <mac address of client>
    <associate client to network>
    Type "show log user-debug 50" and post the output.
  • 3.  RE: Associated client not showing in Clients list
    Posted Nov 17, 2014 05:01 AM
    Please see attached the debug output
    Attachment(s)
    txt
    putty.txt   8 KB 1 version
  • 4.  RE: Associated client not showing in Clients list
    Posted Nov 17, 2014 05:51 AM
    Broaders,
    Is the client DHCP or statically addressed?  What provides DHCP for VLAN 8?
  • 5.  RE: Associated client not showing in Clients list
    Posted Nov 17, 2014 06:30 AM
    The clients are statically assigned addresses.
    It would appear the device is reporting 0.0.0.0? I have seen the config of the device and it does have an IP, but these devices are pretty vague.
    They are Draeger M300 Inifnity devices. I'm thinking the device is causing the issue but I just wanted proof
  • 6.  RE: Associated client not showing in Clients list
    Posted Nov 17, 2014 06:34 AM
    What is the output of "show auth-tracebuf mac 00:30:e6:03:ee:3c"
  • 7.  RE: Associated client not showing in Clients list
    Posted Nov 17, 2014 06:39 AM
    Nov 17 11:37:28 station-up * 00:30:e6:03:ee:3c d8:c7:c8:6a:a5:73 - - static wep
    Nov 17 11:37:28 station-data-ready * 00:30:e6:03:ee:3c 00:00:00:00:00:00 8 -
    Nov 17 11:37:28 station-data-ready_ack * 00:30:e6:03:ee:3c 00:00:00:00:00:00 8 -
  • 8.  RE: Associated client not showing in Clients list
    Posted Nov 17, 2014 06:41 AM
    Hmm...  There is not much there.  Can you try doing it with an Open SSID (no encryption),  just to see if it will connect?
  • 9.  RE: Associated client not showing in Clients list
    Posted Nov 17, 2014 06:51 AM
    Thank for the help so far.
    I will come back to you on this soon as I will need to liaise with the medical team to configure the device.
  • 10.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 10:26 AM
    Hi Colin,
    Hasn't made a difference
    Nov 21 15:22:33 station-up * 00:30:e6:03:ee:3c d8:c7:c8:6a:a5:73 - - open system
    Nov 21 15:22:33 station-data-ready * 00:30:e6:03:ee:3c 00:00:00:00:00:00 8 -
    Nov 21 15:22:33 station-data-ready_ack * 00:30:e6:03:ee:3c 00:00:00:00:00:00 8 -
    New debug log attached, same thing.
    Attachment(s)
    txt
    M300.txt   8 KB 1 version
  • 11.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 10:34 AM
    Okay, try disabling "Wireless Multimedia U-APSD (WMM-UAPSD) Powersave" in the SSID profile under advanced and try again.
  • 12.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 10:35 AM
    It's already disabled (Double checked before posting)
  • 13.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 10:37 AM
    Can we get the output of "show wlan ssid-profile <name of profile>"?
  • 14.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 10:38 AM
    SSID Profile "CTC-M300"
    Parameter Value
    SSID enable Enabled
    ESSID CTCM300
    Encryption opensystem
    DTIM Interval 1 beacon periods
    802.11a Basic Rates
    802.11a Transmit Rates 6 9 12 18 24 36 48 54
    802.11g Basic Rates 1 2
    802.11g Transmit Rates 11 12 18 24 36 48 54
    Station Ageout Time 1000 sec
    Max Transmit Attempts 8
    RTS Threshold 2333 bytes
    Short Preamble Enabled
    Max Associations 64
    Wireless Multimedia (WMM) Enabled
    Wireless Multimedia U-APSD (WMM-UAPSD) Powersave Disabled
    WMM TSPEC Min Inactivity Interval 0 msec
    Override DSCP mappings for WMM clients Disabled
    DSCP mapping for WMM voice AC 48
    DSCP mapping for WMM video AC N/A
    DSCP mapping for WMM best-effort AC N/A
    DSCP mapping for WMM background AC N/A
    Multiple Tx Replay Counters Disabled
    Hide SSID Enabled
    Deny_Broadcast Probes Disabled
    Local Probe Request Threshold (dB) 0
    Disable Probe Retry Enabled
    Battery Boost Disabled
    WEP Key 1 ********
    WEP Key 2 N/A
    WEP Key 3 N/A
    WEP Key 4 N/A
    WEP Transmit Key Index 1
    WPA Hexkey N/A
    WPA Passphrase ********
    Maximum Transmit Failures 0
    EDCA Parameters Station profile N/A
    EDCA Parameters AP profile N/A
    BC/MC Rate Optimization Disabled
    Rate Optimization for delivering EAPOL frames Enabled
    Strict Spectralink Voice Protocol (SVP) Disabled
    High-throughput SSID Profile default
    802.11g Beacon Rate default
    802.11a Beacon Rate default
    Advertise QBSS Load IE Disabled
    Advertise Location Info Disabled
    Advertise AP Name Disabled
    802.11r Profile N/A
    Enforce user vlan for open stations Disabled
  • 15.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 10:41 AM
    Did you try with all the g transmit rates enabled, OR did you try with the basic rates of 11,12?
  • 16.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 10:50 AM
    It seems the device wont associate while all basic rates are enabled.
    It associates again when enabling only 1/2
  • 17.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 11:04 AM
    You are really only supposed to enable two basic rates, and they should be a subset of the TX rates, theoretically.
    e.g.:
    basic 11,12
    tx 11,12....54
    or
    basic 1,2
    tx 1,2,....54
     Is it associating now?
  • 18.  RE: Associated client not showing in Clients list
    Posted Nov 21, 2014 11:05 AM
    Yes it currently is
  • 19.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:06 AM
    I am seeing a similar issue with these exact devices but strangely it is only happening because we have changed the SSID they are connecting to.
    I see the following in the auth-tracebuf:
    Nov 21 16:29:35 mac-auth-req -> 00:30:e6:06:38:42 00:0b:86:94:63:86 - -
    Nov 21 16:29:35 mac-auth-success <- 00:30:e6:06:38:42 00:0b:86:94:63:86 - -
    Nov 21 16:29:35 assg-vlan-req * 00:30:e6:06:38:42 00:0b:86:94:63:86 1 71 new vlan: from mac auth for wireless
    Nov 21 16:29:35 assg-vlan-resp * 00:30:e6:06:38:42 00:0b:86:94:63:86 - 71
    Nov 21 16:29:35 station-up * 00:30:e6:06:38:42 00:0b:86:94:63:86 - - wpa2 psk aes
    Nov 21 16:29:35 wpa2-key1 <- 00:30:e6:06:38:42 00:0b:86:94:63:86 - 117
    Nov 21 16:29:35 wpa2-key2 -> 00:30:e6:06:38:42 00:0b:86:94:63:86 - 117
    Nov 21 16:29:35 wpa2-key3 <- 00:30:e6:06:38:42 00:0b:86:94:63:86 - 175
    Nov 21 16:29:35 wpa2-key4 -> 00:30:e6:06:38:42 00:0b:86:94:63:86 - 95
    The device is associated and shows in the station-table but it doesn't appear to progress further. The IP address is statically assigned and this has not changed across the SSID move.
    We have gone from a WPA2-PSK to another WPA2-PSK just with a different SSID name for consolidation purposes. The same VLAN and IP subnet are used although they are now being allocated via the Aruba VSA. This appears to be working from the auth-tracebuf output.
    Anybody have any information on these devices and whether they need to have the network details reset in any way??
    The supplier is not being very heplful unfortunately.
  • 20.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:09 AM
    It looks like you are using MAC auth to put them into a different VLAN.  Did you want to do that?
  • 21.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:13 AM
    Yes, we want the devices to be in VLAN 71 and we are using a MAC authentication rule on Clearpass to set the Aruba-User-Role attribute. The role has VLAN 71 configured.
  • 22.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:14 AM
    The question is, did this ever work before mac authentication to put it into a different VLAN?
  • 23.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:21 AM
    No, previously the devices were not completing MAC authentication. They were just given the correct role as long as they entered the correct PSK.
    However, the logs on both the Aruba controller and Clearpass show that MAC authentication is passing successfully and the correct user role (with VLAN) is being assigned.
    Also the VLAN they are using hasn't changed. Previously VLAN 71 was the default VLAN configured on the Virtual-AP whereas now it is configured on the user-role assigned as part of MAC authentication.
  • 24.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:25 AM
    dg27,
    To be clear, are you saying that these devices never connected successfully to the network, even in their simplest form without mac authentication or VLAN/Role derivation?
  • 25.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:33 AM
    The devices were previously connected and working.
    The customer is in the process of migrating a series of PSK SSID's into a consolidated single SSID using Clearpass to do MAC authentication and derive the correct user-role and VLAN.
    The original SSID was called 'uhsm-infinity' and was hidden. This was WPA2-PSK but had no MAC authentication and all users were given an allow-all policy and placed in VLAN 71.
    The new SSID is called 'uhsm-psk' and is hidden. This is WPA2-PSK and is doing MAC authentication against Clearpass to assign the correct user-role where the VLAN is specified (71). Other devices connect to this SSID and are assigned different user-roles (and VLANs).
    Below is a station-table output showing a device associated to the old 'uhsm-infinity' SSID and a device associated to the new 'uhsm-psk' SSID:
    Station Entry
    MAC Name Role Age(d:h:m) Auth AP name Essid Phy Remote Profile
    00:30:e6:04:fa:a6 uhsm_infinity 01:16:28 No Ward F6 left uhsm-infinity g No uhsm_ infinity_aaa
    00:30:e6:04:fc:01 00:30:e6:04:fc:01 uhsm-psk-infinity 00:00:05 Yes Outside Sleep Lab uhsm-psk g No uhsm-psk_ AAA
    The device connected to uhsm-infinity is working the device connected to uhsm-psk is not even though both show as associated.
    Appreciate the assistance with this.
  • 26.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:37 AM
    David,
    Thanks for taking the time to explain this.
    Okay.  Let's try this:
    - Remove the VLAN from the role
    - In the ClearPass enforcement profile that you are using to return the role, please try to return the VLAN like this:
  • 27.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:42 AM
    I'll make those changes and feed back as to whether this improves anything.
  • 28.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 07:47 AM
    David,
    Please compare all of the SSID profile settings between the first SSID and the new SSID to make sure everything matches.  There are a few settings like the rates, and Powersave that need to match, according to the user that originally opened this thread...
  • 29.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 08:01 AM
    Thanks Colin.
    The AAA, SSID and Virtual-AP profiles are as similar as I can make them.
    We just attempted a connection with the Aruba-User-Vlan assigned from Clearpass but get the same. Some outputs below:
    auth-tracebuf:
    Nov 24 12:55:02 mac-auth-req -> 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 - -
    Nov 24 12:55:02 mac-auth-success <- 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 - -
    Nov 24 12:55:02 assg-vlan-req * 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 1 71 new vlan: from mac auth for wireless
    Nov 24 12:55:02 assg-vlan-resp * 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 - 71
    Nov 24 12:55:02 station-up * 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 - - wpa2 psk aes
    Nov 24 12:55:02 wpa2-key1 <- 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 - 117
    Nov 24 12:55:02 wpa2-key2 -> 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 - 117
    Nov 24 12:55:02 wpa2-key3 <- 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 - 175
    Nov 24 12:55:02 wpa2-key4 -> 00:30:e6:04:fc:01 00:1a:1e:01:cf:c6 - 95
    (Aruba-1) # show station-table mac 00:30:e6:04:fc:01
    Association Table
    BSSID AP IP Essid AP name Phy Age
    00:1a:1e:01:cf:c6 192.168.196.239 uhsm-psk FB-1F-Corridor_F3/4 g- 00:00:01
    (Aruba-1) #show user mac 00:30:e6:04:fc:01
    The phy column shows client's operational capabilities for current association
    Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client
    PHY Details: HT : High throughput; 20: 20MHz; 40: 40MHz
    VHT : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
    <n>ss: <n> spatial streams
    Association Table
    Name bssid mac auth assoc aid l-int essid vlan-id tunnel-id phy assoc. time num assoc Flags Band steer moves (T/S)
    FB-1F-Corridor_F3/4 00:1a:1e:01:cf:c6 00:30:e6:04:fc:01 y y 1 16 uhsm-psk 71 0x10506 g 1m:59s 1 A 0/0
    00:30:e6:04:fc:01-00:1a:1e:01:cf:c6 Stats
    Parameter Value
    Channel 11
    Channel Frame Retry Rate(%) 0
    Channel Frame Low Speed Rate(%) 0
    Channel Frame Non Unicast Rate(%) 0
    Channel Frame Fragmentation Rate(%) 0
    Channel Frame Error Rate(%) 4
    Channel Bandwidth Rate(kbps) 0
    Channel Noise 101
    Client Frame Retry Rate(%) 0
    Client Frame Low Speed Rate(%) 0
    Client Frame Non Unicast Rate(%) 0
    Client Frame Fragmentation Rate(%) 0
    Client Frame Receive Error Rate(%) 0
    Client Bandwidth Rate(kbps) 0
    Client Tx Packets 4
    Client Rx Packets 3
    Client Tx Bytes 320
    Client Rx Bytes 422
    Client SNR 27
    (Aruba-1) # show user-table | include 00:30:e6:04:fc:01
    (Aruba-1) #
    I've also attached the user-debug log for this association.
    Attachment(s)
  • 30.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 08:11 AM
    David,
    The main thing that matters is the SSID profile.  What differs between the two?
    The auth-tracebuf looks like it completes the four-way handshake.  How is the auth-tracebuf  different from the old SSID?
    Does the device appear in the user table?
  • 31.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 08:26 AM
    I've been through the SSID profiles of both services and they are identical apart from the WMM DSCP mapping values being configured on the old service. However, WMM is not enabled and the override setting is not set.
    The device does NOT appear in the user-table.
    We have connected a laptop to the SSID and this works without issue with a static IP address configured. It looks like the devices causing the problem.
  • 32.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 08:28 AM
    Same issue as me, reports the IP as 0.0.0.0.
    What version of code is the the M300 device running. FYI ours is 8.10
  • 33.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 08:32 AM
    Yes 8.10 this end as well.
    The device appears to go in to a boot cycle where the configuration is not accessible. We've been told to get out of this you need to take the device out of range of the wireless. However, we've reconfigured a device from scratch and it won't connect.
  • 34.  RE: Associated client not showing in Clients list
    Posted Nov 24, 2014 09:32 AM
    I think I will raise the issue with Draeger as I just dont see the issue with the wireless side.
    We can associate laptops etc to the network just fine with a static IP.
    I have seen this boot loop aswell, although we experienced it when we tried to change to WPA.
    I just wonder if there is something not quite right with the 8.10 firmware.
  • 35.  RE: Associated client not showing in Clients list
    Posted Jul 10, 2015 10:26 AM
    We were dealing with this exact issue.  I'm not sure if anyone tried to ping the M300 after it was connected to the AP, but this will show the client as an active user on the controller.
    The real solution here is to have the Draeger Central Station poll the device.  When they did this, the M300 showed up as a client on the controller.  The Central Station may get an minor error at first, but every subsequent poll will be successful.  And these units tend to stay connected.  I did not do a sniffer trace, but my guess is that this device does not look for it's gateway (like a Windows or Apple device does) after it associates with the AP.
