ath_key_reset: MAC is busy. Reseting radio
  • 1.  ath_key_reset: MAC is busy. Reseting radio
    Posted Jun 27, 2013 05:05 AM
    Hi
    Can anyone advise what means "ath_key_reset: MAC is busy. Reseting radio" log below?
    Does it affect wireless connection or authenticaion?
    Regards
    Simon
    show ap debug driver-log ap-name "AP001215_AOseizo"
    Driver Log
    Current Log Level 3 Log Counter 53 Timestamp  5293613.485524
    1           0.0      aruba100: Scheduling VAP CONFIG update
    2           0.312    aruba100: Encryption Mode Set to 4
    3           0.362    aruba100: WPS Mode Set to 0
    4           0.396    aruba100: 40mhz enable to 1
    5           0.429    aruba100: 40mhz GI to 1
    6           0.460    aruba100: STBC TX streams to 1
    7           0.492    aruba100: STBC RX streams to 1
    8           0.524    aruba100: Beacon rate to 1000
    9           0.560    aruba100: A-MPDU: Enabled, Tx Max 65535 Rx Max 3 Min Spacing 6
    10          0.605    aruba100: Basic Rate Set to 3
    11          0.637    aruba100: Supported Rate Set to fff
    12          0.674    aruba100: DTIM Period Set to 1
    13          0.674    aruba100: ESSID Set to JPN-WL-NW
    14          0.674    aruba100: Max Retries Set to 8
    15          0.674    aruba100: RTS Threshold Set to 2333
    16          0.674    aruba100: Ageout Set to 1000
    17          0.674    aruba100: WMM DISABLED
    18          0.674    aruba100: VAP CONFIG DONE
    19          0.16118  wifi1: Country Code Set to JP
    20          0.26874  wifi1: EIRP (Config: 0.-5dBm, Set: 20.0dBm, AP Max: 20.0dBm, Reg Max: 20dBm), Conducted Power Set: 20.0dBm, Gain: 0.0dBm
    21          0.26943  wifi1: Channel Set to 11 (mesh-mode: 0, state: 0)
    22          0.26984  wifi1: Internal Antenna Gain Set to 2.5 dB for 2.4 GHz
    23          0.27022  wifi1: Internal Antenna Selected
    24          0.27182  wifi1: EIRP (Config: 24.0dBm, Set: 20.0dBm, AP Max: 22.5dBm, Reg Max: 20dBm), Conducted Power Set: 17.5dBm, Gain: 2.5dBm
    25          0.27242  wifi1: disabling 40Mhz
    26          0.27293  wifi1: RADIO CONFIG DONE
    27          0.33602  wifi1: Scheduling RADIO CONFIG update
    28          0.37132  wifi1: Country Code Set to JP
    29          0.58316  wifi1: EIRP (Config: 24.0dBm, Set: 7.5dBm, AP Max: 22.5dBm, Reg Max: 20dBm), Conducted Power Set: 5.0dBm, Gain: 2.5dBm
    30          0.58387  wifi1: Channel Set to 11 (mesh-mode: 0, state: 5)
    31          0.58428  wifi1: Internal Antenna Gain Set to 2.5 dB for 2.4 GHz
    32          0.58468  wifi1: Internal Antenna Selected
    33          0.58505  wifi1: Antenna Mode Selected: AUTO
    34          0.58541  wifi1: disabling 40Mhz
    35          0.58588  wifi1: RADIO CONFIG DONE
    36     196155.254072 ath_key_reset: MAC is busy. Reseting radio
    37     306926.329098 ath_key_reset: MAC is busy. Reseting radio
    38     451663.747498 ath_key_reset: MAC is busy. Reseting radio
    39     802219.303476 ath_key_reset: MAC is busy. Reseting radio
    40     2117485.224168 ath_key_reset: MAC is busy. Reseting radio
    41     3131989.76924  ath_key_reset: MAC is busy. Reseting radio
    42     3164581.673496 ath_key_reset: MAC is busy. Reseting radio
    43     3402043.436891 ath_key_reset: MAC is busy. Reseting radio
    44     3904357.234959 ath_key_reset: MAC is busy. Reseting radio
    45     3907764.155897 ath_key_reset: MAC is busy. Reseting radio
    46     4536776.196264 ath_key_reset: MAC is busy. Reseting radio
    47     4537379.961135 ath_key_reset: MAC is busy. Reseting radio
    48     4537824.988923 ath_key_reset: MAC is busy. Reseting radio
    49     4538634.378188 ath_key_reset: MAC is busy. Reseting radio
    50     4967207.22191  ath_key_reset: MAC is busy. Reseting radio
    51     4981542.474200 ath_key_reset: MAC is busy. Reseting radio
    52     5117068.39064  ath_key_reset: MAC is busy. Reseting radio
  • 2.  RE: ath_key_reset: MAC is busy. Reseting radio
    Posted Jun 27, 2013 08:44 AM
    It could be a hardware issue.  What version of ArubaOS and what type of access point?
  • 3.  RE: ath_key_reset: MAC is busy. Reseting radio
    Posted Jun 27, 2013 09:13 PM
    Cjoseph
    6.1.3.6 with AP105 is used.
    6 clients are associated now, so not so many clients are on AP..
    Regards
    Simon
  • 4.  RE: ath_key_reset: MAC is busy. Reseting radio
    Posted Jun 27, 2013 11:10 PM
    @sai45mon10 wrote:
    Hi
    Regards
    Simon
    Driver Log
    The message is a debug message and in itself does not say anything.  It is possible to see that message when the radio gets a new config and needs to reset.  The timestamp before the decimal represents the number of seconds since the access point has been up, so most of those messages are spaced out.  Nothing else is being logged so it seems that message is a problem, but by itself, it is not.
