As @Jamie E mentioned: "The Atmosphere content is only accessible to Atmosphere attendees right now. If you attended Atmosphere and do not have access it's because you registered for the event with a different email than the one associated with your Airheads account. Let me know and I can correct that for you if that's the case."
I can see the recordings on the link that Jamie shared above.
Original Message:
Sent: Oct 28, 2024 04:00 PM
Subject: Atmosphere 2024 Recordings
Any update on this? I attended Atmosphere 2024 but I am not able to access the recordings at the link above. Is anyone else able to see these? I was able to access the slides in the Discover App but not the recordings.
Original Message:
Sent: Sep 18, 2024 06:52 AM
Thanks Jamie. Any idea if and when the recordings may be generally released?
Original Message:
Sent: Sep 18, 2024 06:12 AM
Yes, the embeds have been corrected.
Original Message:
Sent: 9/18/2024 4:22:00 AM
Subject: RE: Atmosphere 2024 Recordings
Hi Jamie,
Did you have any luck trying to get the recordings back accessible?
Thanks!
Original Message:
Sent: Sep 11, 2024 06:05 AM
Sorry to hear that, Ill get it sorted for you.
Original Message:
Sent: 9/10/2024 5:45:00 PM
I was able to watch them last week too, but now they are also gone for me.
Original Message:
Sent: Sep 09, 2024 01:53 PM
Worked for me this morning now I get message below:
No Data Found Either the content you're seeking doesn't exist or it requires proper authentication before viewing.
Original Message:
Sent: Sep 06, 2024 07:00 AM
The recordings are available for Discover attendees. You can find them here.
Original Message:
Sent: Aug 21, 2024 12:18 PM
It's been two months, any updates on when / where the Atmoshphere recordings will be posted? These typically have been available within a couple weeks in the past, seems odd that we haven't heard anything in 2 months.
