AT&T USBConnect Momentum 4G
  • 1.  AT&T USBConnect Momentum 4G
    Posted Sep 16, 2014 10:47 AM
    Has any one been able to configure & use an AT&T USBConnect Momentum 4G as a WAN uplink for a RAP-155P?
    Tried USBConnect881, but that doesn't work; different devices.
    This device looks to have a microSD slot, it may be showing up as a storage device however I'm not sure how I can tell.   Gonna try to poke around the logs to see what I can find.
    Sep 16 10:40:06 KERNEL(dc3-rap-8ea5@(none)): usb 1-1: config 1 has an invalid interface number: 9 but max is 0
    Sep 16 10:40:06 KERNEL(dc3-rap-8ea5@(none)): usb 1-1: config 1 has no interface number 0
    Any tips or recommendations on how to get this to work would be appreciated.
    TIA,
  • 2.  RE: AT&T USBConnect Momentum 4G
    Posted Sep 16, 2014 11:05 AM
    Some info on the USB interface from the RAP.
    #show ap debug usb ap-name dc3-rap-8ea5
    USB Information
    Parameter         Value
    Manufacturer       Sierra
    Product            USB
    Serial Number      SWOC22905731
    Driver             (none)
    Vendor ID          1199
    Product ID         0fff
    USB Modem State    Standby
    (viavpn1) #
    Oh, and the driver log info :
    #show ap debug driver-log ap-name dc3-rap-8ea5
    tarted, EHCI 1.00
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: Marvell Orion EHCI
    usb usb1: Manufacturer: Linux 2.6.32.11 ehci_hcd
    usb usb1: SerialNumber: ehci_marvell.70059
    usb usb1: configuration #1 chosen from 1 choice
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    usb 1-1: new high speed USB device using ehci_marvell and address 2
    usb 1-1: New USB device found, idVendor=1199, idProduct=0fff
    usb 1-1: New USB device strings: Mfr=3, Product=2, SerialNumber=4
    usb 1-1: Product: USB MMC Storage
    usb 1-1: Manufacturer: Sierra Wireless, Incorporated
    usb 1-1: SerialNumber: SWOC22905731
    usb 1-1: configuration #1 chosen from 1 choice
    usb-storage: device ignored
    USB Serial support registered for Sierra USB modem
    usbcore: registered new interface driver sierra
    sierra: v.1.7.40:USB Driver for Sierra Wireless USB modems
    bond0: no IPv6 routers present
    ethsw: no IPv6 routers present
    usbcore: deregistering interface driver usb-storage
    Uniform CD-ROM driver unloaded
    Kernel watchdog refresh ended.
    wlan: 0.8.4.2 (Atheros/multi-bss)
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    ath_attach: scn cd3c0320 sc cd260000 ah cd2c0000
    wifi0: Base BSSID 6c:f3:7f:79:da:70, 16 available BSSID(s)
    eth0 address=00:0b:86:8f:8e:a5
    br0 address=00:0b:86:8f:8e:a5
    wifi0: AP type RAP-155P, radio 0, max_bssids 16
    wifi0: Atheros 9580: mem=0xf3000000, irq=25 hw_base=0xd1dc0000
    ath_attach: scn cc880320 sc cc8a0000 ah cc8c0000
    wifi1: Base BSSID 6c:f3:7f:79:da:60, 16 available BSSID(s)
    wifi1: AP type RAP-155P, radio 1, max_bssids 16
    wifi1: Atheros 9580: mem=0xf4000000, irq=24 hw_base=0xd1f40000
    ath_ahb: 0.9.4.5 (Atheros/multi-bss)
    ath_ahb: No devices found, driver not installed.
    kat driver unloaded
    br0: no IPv6 routers present
    stpdev: no IPv6 routers present
    ADDRCONF(NETDEV_UP): eth2: link is not ready
    ADDRCONF(NETDEV_UP): eth3: link is not ready
    ADDRCONF(NETDEV_UP): eth4: link is not ready
    ADDRCONF(NETDEV_CHANGE): eth4: link becomes ready
    ADDRCONF(NETDEV_CHANGE): eth3: link becomes ready
    eth4: no IPv6 routers present
    eth3: no IPv6 routers present
    usb 1-1: USB disconnect, address 2
    Sending the signal to sapd
    usb 1-1: new high speed USB device using ehci_marvell and address 3
    eth0: link down
    bonding: bond0: link status definitely down for interface eth0, disabling it
    bonding: bond0: now running without any active interface !
    eth0: link up, full duplex, speed 100 Mbps
    bonding: bond0: link status definitely up for interface eth0.
    bonding: bond0: making interface eth0 the new active one.
    bonding: bond0: first active interface up!
    Driver Log
    Current Log Level 3 Log Counter 1 Timestamp        0.0
     Gonna try to hunt down usb-modeswitch params.
  • 3.  RE: AT&T USBConnect Momentum 4G
