Attribute assistance; time manipulation
  • 1.  Attribute assistance; time manipulation
    Posted Oct 01, 2016 09:10 AM
    Hi team,
    I have an attribute value defined as,
    'Mac Auth Expiry' = %{Authorization:[Time Source]:Now Plus 90 days}
    (Where 'Now Plus 90 days' is an attribute defined in [Time Source].. no issues here.  That works fine.)
    I want to define another attribute of 'Mac Auth Remaining Expiration' which is basically something in the order of,
    'CASE WHEN Mac Auth Expiry > EPOCH FROM NOW() THEN CAST(EXTRACT(EPOCH FROM (Mac Auth Expiry - NOW())) AS INTEGER) ELSE 0 END AS Mac Auth Expiration Remaining'
    SQL wise that is...
    A 'remaining' leveraging EPOCH NOW minus the prior attribute.
    Thoughts ?
  • 2.  RE: Attribute assistance; time manipulation
    Posted Oct 01, 2016 09:18 AM
    Where is the original MAC-auth expiration defined?
    Also, why not use the built-in MAC-caching logic which does not require any custom queries.
  • 3.  RE: Attribute assistance; time manipulation
    Posted Oct 01, 2016 09:28 AM
    Type = Endpoint
    Name = Mac Auth Expiry
    Value = %{Authorization:[Time Source]:Now Plus 90 days}
    Defined as post-auth type enforcement profile.
    You mean the 'Device MAC Authentication' template ?
    That has aging examples in it ?
  • 4.  RE: Attribute assistance; time manipulation
    Posted Oct 01, 2016 09:31 AM
    All you have to do is compare the current time to the endpoint MAC-auth expiry attribute in either your role map or enforcement policy. No custom SQL queries are required. This is a standard set up for guest authentication but will work with anything.
  • 5.  RE: Attribute assistance; time manipulation
    Posted Oct 01, 2016 09:55 AM
    There is the Guest 'MAC Caching' service template that does do the basic, NOW LESS THAN '%{Endpoint:mac auth expiry}'.
    But, it's basic.. and the operators are just as basic.  I.e. GREATER_THAN, GREATER_THAN_OR_EQUALS.. etc.
    I want do a RADIUS 'Session-Timeout'.. so it needs to be literally, 'current set mac auth expiry minus now'..
    Similar to how the guest database has the prior quoted sql to do the 'expiration'.
  • 6.  RE: Attribute assistance; time manipulation
    Posted Oct 01, 2016 09:56 AM
    I'll get the SQL built. All good.
  • 7.  RE: Attribute assistance; time manipulation
    Posted Oct 23, 2018 02:15 PM
    Any advancement on this?  i'm looking to do this with a session timer as well.  Mac-Auth Expiry minus now converted to integer for a switch session timer.
  • 8.  RE: Attribute assistance; time manipulation
    Posted Oct 25, 2018 04:30 PM
    Have you tried
    Radius:IETF Session-Timout = %{Authorization:[Guest User Repository]:RemainingExpiration]}
    This is the default guest session timeout profile.
  • 9.  RE: Attribute assistance; time manipulation
    And no existing attributes sitting in the [Endpoint Repo].. that help with MAC Caching examples.
