which aruba access point models work with the 7210 with a firmware version of 6.4.4.9?
Unfortunately, there is no chart in the release notes of 6.x that say what version of ArubaOS is supported. You can take a look at this for the minimum supported firmware version: https://community.arubanetworks.com/aruba/attachments/aruba/Chinese/140/1/MAT_AP.pdf
Or, if you google "ArubaOS 345 access point datasheet", for example, the datasheet will say what the minimum is.
