autenticacion por portal captivo
  • 1.  autenticacion por portal captivo
    Posted Mar 16, 2015 07:45 PM
    good day
    I need a help with an issue of authentication by captive portal, the problem is that it requires the user credentials only the first time you connect the ssid, and when you reconnect you are not prompted credentials, that way I can resolve this in a solution with controller.
    thank you very much for the collaboration
  • 2.  RE: autenticacion por portal captivo
    Posted Mar 16, 2015 08:05 PM
    You will need ClearPass to do something like this
  • 3.  RE: autenticacion por portal captivo
    Posted Mar 16, 2015 11:36 PM
    you never want them to authenticate again or do you mean just for a day? What are the users authenticating to? Local accounts or external auth sever?
