Auth-survivability issue
  • 1.  Auth-survivability issue
    Posted Apr 27, 2017 01:39 AM
    Hi
    I have enabled auth-survivability on your controllers. I can see in that the controller is caching EAP-TLS clients but nor EAP-PEAP clients. It's the same on 72xx and 70xx controllers. Prevoius software versions did cache EAP-PEAP clients. Is this a bug ?
    Guest users are cached as well.
    Running ArubaOS: 6.5.0.4
    Auth-survivability is set to 24 hours.
    BR
    Bjørn Vollelv
  • 2.  RE: Auth-survivability issue
    Posted Apr 27, 2017 06:11 AM
  • 3.  RE: Auth-survivability issue
    Posted Apr 27, 2017 07:07 AM
    Thanks for your replay.
    If I have understood you correctly is that EAP-PEAP is not supported anymore. This was working in earlier versions.
  • 4.  RE: Auth-survivability issue
    Posted Apr 27, 2017 11:25 AM
    Please open a TAC case.
  • 5.  RE: Auth-survivability issue
    Posted Apr 30, 2017 03:34 PM
    I'm pretty sure EAP-TLS & EAP-PEAP used to be supported on the MAS switches were you thinking of this perhaps?
  • 6.  RE: Auth-survivability issue
    Posted May 02, 2017 01:18 AM
    I was thinking that it was supported on the controllers.
