Auth survivability with EAP-PEAP
  • 1.  Auth survivability with EAP-PEAP
    Posted Jun 27, 2019 01:24 AM
    Will Auth survivability option support for 802.1X supplicants using EAP PEAP for authentication.
    Currently we have enabled Auth survivability on 7205 controller running on 6.5.4.12 version. We are using CPPM 6.7 as authentication server and configured SSID with 802.1X authentication.
    Authentication is working fine but when we try to check user cache in controller using # show aaa auth-survivability-cache it is empty.
    Any other pre-requisites in necessary for it to work in EAP PEAP , do we need to upload CPPM server radius certificate into Controller to use as server certificate .
    In CPPM end should we enable/disable Terminate session in wireless service created.
    Thank you.
  • 2.  RE: Auth survivability with EAP-PEAP
    Posted Jun 27, 2019 01:28 AM
    Legacy EAP methods like PEAP are not supported.
  • 3.  RE: Auth survivability with EAP-PEAP
    Posted Jun 27, 2019 02:05 AM
    Thank you
