auth trace buffer showing eap-id-mismatch
  • 1.  auth trace buffer showing eap-id-mismatch
    Posted Nov 06, 2012 09:14 AM
    anyone encountered this message in the auth trace buffer: eap-id-mismatch, what would it point to?
    this is the full trace buffer surrounding it:
    Nov 6 14:59:42 station-up * 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 - - wpa2 aes
    Nov 6 14:59:42 eap-id-req <- 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 1 5
    Nov 6 14:59:42 eap-start -> 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 - -
    Nov 6 14:59:42 eap-id-resp -> 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 1 27 AD
    ame
    Nov 6 14:59:42 rad-req -> 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 9 209
    Nov 6 14:59:42 rad-resp <- 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71/radius2 9 122
    Nov 6 14:59:42 eap-req <- 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 2 38
    Nov 6 14:59:42 eap-id-mismatch * 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 - -
    Nov 6 14:59:42 eap-nak -> 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 2 6
    Nov 6 14:59:42 rad-req -> 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71/radius2 10 226
    Nov 6 14:59:42 rad-reject <- 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71/radius2 10 56
    Nov 6 14:59:42 eap-failure <- 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 2 4 server rejected
    Nov 6 14:59:42 station-down * 00:56:6a:2d:5c:70 6c:f3:dd:db:0e:71 - -
  • 2.  RE: auth trace buffer showing eap-id-mismatch
    Posted Nov 07, 2012 04:02 PM
    it might be the type of EAP used e.g. CHAP, TLS, MSCHAPv2, etc
    check that both of them are of the same type.
