Authenticated guests on guest wifi randomly disconnected when MAC filter activated
  • 1.  Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 08, 2017 04:55 AM
    We have an issue with our guest SSID on Aruba Instant AP 205.
    The guest wifi is configured to use both MAC authetification and username/password.
    The problem is that guests who authenticate with username/password get disconnected after random time (and not the one setted up into the configuration) and have to reconnect.
    After some tests we noticed that there is no disconnection when we disable the MAC authentification (but we need it...). We believe that the AP check the MAC adress for time to time and disconnect the user if the MAC is not authorized...
    Any idea on how to resolve this issue?
    Thank you,
    Cyril
  • 2.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 08, 2017 08:44 AM
    You should look in the access tracker to see if there is any activity on that client...
  • 3.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 09, 2017 04:36 AM
    Thank you for your reply.
    Is the access tracker available on the AP205 ? We are not using a physical controller or clearpass.
    Cyril
  • 4.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 09, 2017 06:26 AM
    I apologize.
    Is this a controller-based deployment?  Are you turning on the mac filter by enabling mac authentication?  What is your mac authentication configuration?
  • 5.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 11, 2017 10:46 PM
    We have configured a virtual controller.
    Yes we have enabled the MAC authenthication on the security tab of the guest wifi configuration setup (see attached picture).
    Let me know if you need more information.
    Thank you for your help,
    Cyril
  • 6.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 11, 2017 11:08 PM
    That is a picture of the transmit power...
  • 7.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 12, 2017 12:14 AM
    Sorry wrong file... Here is the correct picture.
  • 8.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 12, 2017 06:21 AM
    According to that picture, guests are forced to reauthenticate after 24 hours.  That should not be triggered unlesss your guests are connected for 24 hours straight.  I would set the reauthentication interval to 0 and see if it continues to happen.
  • 9.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 12, 2017 10:19 PM
    I have changed the reauthentication interval to 0 and the issue still happen.
    Cyril
  • 10.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 13, 2017 12:34 AM
    Mac authentication should not allow a user to connect if their mac address is not in the list.  It should not disconnect them after that.
    When you say disconnect, what you do mean?  What happens?  Does the user lose their ip address?
    What kind of authentication are you using besides mac authentication on this SSID?
  • 11.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 13, 2017 01:33 AM
    We are using this SSID for two ways of authetication :
    - MAC authentication : MAC adresses are registered into the user list and the clients can access the WiFi without having to login on the captive portal. This one works great.
    - User authentication : We create login ID/password for guest to be able to access our guest wifi via the captive portal. Here is where we have a problem. The users can connect and access the Internet but they are randomly, and very often, disconnected, that mean that the captive portal ask them to connect again with their ID/password.
    For testing purpose, we have created an other guest wifi with the same parameters except the MAC authentication, and the users with ID/password are not disconected after authenticate on the captive portal.
    Cyril
  • 12.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 13, 2017 01:41 AM
    Can we see your entire configuration for that SSID?
  • 13.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 13, 2017 01:55 AM
    wlan access-rule WIFI-EXT
    index 3
    rule 10.0.0.0 255.0.0.0 match any any any deny
    rule 172.16.0.0 255.240.0.0 match any any any deny
    rule 192.168.0.0 255.255.0.0 match any any any deny
    rule any any match any any any permit
    wlan ssid-profile WIFI-EXT
    enable
    index 1
    type guest
    essid LSG-WIFI-EXT
    opmode opensystem
    max-authentication-failures 0
    vlan guest
    auth-server InternalServer
    rf-band all
    captive-portal internal
    mac-authentication
    mac-authentication-delimiter :
    dtim-period 1
    inactivity-timeout 3600
    broadcast-filter all
    g-min-tx-rate 11
    a-min-tx-rate 18
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
  • 14.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 13, 2017 02:04 AM
    You are missing a rule on top that allows DHCP from any to any.
  • 15.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 13, 2017 04:15 AM
     index 3
     rule any any match udp 67 68 permit
    Still the same :(.
  • 16.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 22, 2017 10:38 PM
    We are still affected by the problem, any new idea on how to resolve it?
    Cyril
  • 17.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 22, 2017 10:54 PM
    What subnet are your guests on?
  • 18.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 22, 2017 11:05 PM
    The subnet is 10.65.223.0/24
  • 19.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 23, 2017 06:57 AM
    What server is providing DHCP for this network? (IP address)
    Have you considered not blocking anything for 24 hours and seeing if you still have the issue?
  • 20.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jun 26, 2017 11:03 PM
    The DHCP is managed by the virtual controller (10.65.2.244).
    Yes we have tried without any rules and it does not resolve the issue. The only thing that we found to resolve it is to disable the MAC authentification.
    Cyril
  • 21.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jul 20, 2017 10:24 PM
    Any new idea over here? We still face the problem.
    Cyril
  • 22.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jul 20, 2017 10:41 PM
    Your a-min-tx-rate is pretty high at 18.  Your clients would have to be very close to use a number that high.  I would start with the default back at 6.
  • 23.  RE: Authenticated guests on guest wifi randomly disconnected when MAC filter activated
    Posted Jul 21, 2017 12:10 AM
    Thanks for your help, I tried with 6 but it does not fix the problem.
