Authentication
  • 1.  Authentication
    Posted Jan 25, 2013 12:11 AM
    In deployment , what type of authentication (Internal or external) is mostly preferred.
    What my openion is, it will be external authentication as it will be easy to update external database incase of any changes/deletion of
    user from database.
    Please correct me if am wrong.
    Appreciate your early response.
  • 2.  RE: Authentication
    Posted Jan 25, 2013 09:04 AM
    For guest networks, accounts and authentication are typically handled within the controller or ClearPass Guest if you own it.   For employee networks that use 802.1X, an external directory source is typically recommended as it already contains the user accounts and passwords.  You'll need a RADIUS server to interface between the controller and the directory.
    If the environment does not have any external database, the choice is really yours.  You could create the accounts internally or externally.  If you use the internal DB and are using 802.1X, you'll need to enable EAP termination on the controller in the dot1x Authentication Profile.
  • 3.  RE: Authentication
    Posted Jan 27, 2013 11:27 PM
    Thanks Clembo
