authentication failure - Invalid response code received from server
  • 1.  authentication failure - Invalid response code received from server
    Posted Nov 21, 2016 08:57 AM
    this is the error i get when i run my php script for sending email authentication failure [SMTP: Invalid response code received from server (code: 535, response: 5.7.0 ...authentication rejected)]
    this are the smtp configurations i have done
     $from="postmaster";$headers = array ('From' => $from,
    'To' => $to,
    'Subject' => $subject);
    $host="ssl://smtp.aruba.it";$port="465";$username="info@****.com";$password="*****";
    $body = $mime -> get();$headers = $mime -> headers($headers);$smtp= Mail::factory('smtp',array('host'=>$host, 'port'=>$port,'auth' => true,
        'username' => $username,
        'password' => $password));
    $query="SELECT * from payment where iduser='$iduser'";$result=mysql_query($query);
    while ($row=mysql_fetch_array($result)) {
        if ($row['amount'] > 0)$mail = $smtp->send($to, $headers, $body);
    if (PEAR::isError($mail)) {  echo("<p>" . $mail->getMessage() . "</p>");
  • 2.  RE: authentication failure - Invalid response code received from server
    Posted Nov 21, 2016 09:01 AM
    Where are you running the script?
  • 3.  RE: authentication failure - Invalid response code received from server
    Posted Nov 21, 2016 09:04 AM
    what do you mean by where? i am calling the php file in javascript
  • 4.  RE: authentication failure - Invalid response code received from server
    Posted Nov 21, 2016 09:05 AM
    Yes, but from where? Please provide some context on your setup.
  • 5.  RE: authentication failure - Invalid response code received from server
    Posted Nov 21, 2016 09:08 AM
    This script sends automatic emails(user credentials) when it is called, and it is called in javascript at the moment when a user click the button registrate. At that moment is shown this error, i don't know if i am clear
  • 6.  RE: authentication failure - Invalid response code received from server
    Posted Nov 21, 2016 09:10 AM
    the email i am using to send messages is registered in aruba that's why i have used as host: smtp.aruba.it
  • 7.  RE: authentication failure - Invalid response code received from server
    Posted Nov 21, 2016 02:38 PM
    - What host are you sending the email from?
    - Is this script running on a client captive portal?  If not, what server is it running on?
