Comware
last person joined: 4 hours ago
Authentication for SSH users by an LDAPS
  • 1.  Authentication for SSH users by an LDAPS
    Posted Apr 08, 2022 04:24 PM
    LDAP for ssh authentication works fine.
    ip 10.10.10.10 port 389
    Does the HP flexFabric 5700, 5800 support LDAPS? The LDAPS  always displays "access denied"
    ip 10.10.10.10 port 636
    I followed the instructions to setup LDAP:
    HPE FlexFabric 5710 Switch Series Security Configuration Guide
    https://techhub.hpe.com/eginfolib/networking/docs/switches/5710/5200-5002_security_cg/content/index.htm
    reagrds
    medera
    ana medera
  • 2.  RE: Authentication for SSH users by an LDAPS
    Posted Apr 29, 2022 02:29 AM
    Configure the switch to meet the following requirements:
    • Use the LDAP server to authenticate SSH users.
    • Assign the level-0 user role to SSH users after they pass authentication.
    James Gross
  • 3.  RE: Authentication for SSH users by an LDAPS
    Posted Apr 29, 2022 02:58 AM
    In the documentation for 5700 and 58xx series (BTW, 58xx are running Comware 5, old and unsupported) there is no mention for LDAPS or LDAP over TLS. The command 'protocol-version' has only two arguments: 'v2' and 'v3', so I am afraid when you point the port 636, the switch tries to use clear-text LDAP on that port, not TLS, that is the most probable cause why it fails.
    Ivan Bondar
