Authentication issue in a access point
  • 1.  Authentication issue in a access point
    Posted Dec 14, 2017 11:09 AM
    I have an access point in a room . and this access point is working fine before a month suddenly it is not allowing none of the users to connect with the configured SSID . As checked the access point and and virtual controller having one possible error on it that is below ,
    " Too many authentication error (148 retries)" . and i ahve attached the error log snap for the refrence .
    All the users are able to connect with all other AP . and none of the users are connect with the accespoint , which have many authentication errors in it .
    Hope some will help me soon.
  • 2.  RE: Authentication issue in a access point
    Posted Dec 14, 2017 07:19 PM
    Is this an instant ap (IAP) or Campus AP?
    What version of software are you running?
  • 3.  RE: Authentication issue in a access point
    Posted Dec 15, 2017 12:42 AM
    Yes its a IAP (vc running inside of this AP) and i will share the version soon . could you tell me what is campus AP?
  • 4.  RE: Authentication issue in a access point
    Posted Dec 15, 2017 09:08 AM
    It can either be an IAP or a Campus (AP controlled by a controller) AP.   Yours is an IAP (Instant AP).
  • 5.  RE: Authentication issue in a access point
    Posted Dec 18, 2017 03:32 AM
    AP model : 105
    Firmware:6.4.2.3-4.1.1.2_48114
    I hope i will get the solution asap .
  • 6.  RE: Authentication issue in a access point
    Posted Dec 18, 2017 06:52 AM
    That version of code is very old and most likely has bugs.  I would attempt to upgrade to a later version of code here:
    http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/20374/Default.aspx
  • 7.  RE: Authentication issue in a access point
    Posted Jan 02, 2018 09:56 AM
    Hi Colin,
    As checked i could not find any option to upgrade through VC ( Remotly)
    And i am using IAP 105 model . Hope i have to upgrade this by using console port in the AP but i don't know how to do that,
    Can you please send me the manual or the detailed procedure to upgrade the latest firmware of  IAP 105 model ?
  • 8.  RE: Authentication issue in a access point
    Posted Jan 02, 2018 09:59 AM
    The given links shows many firmware files  and i don't know which one is required for me , Can please clarify that also
  • 9.  RE: Authentication issue in a access point
