Hello
We got a deployment in which we have multiple local controllers aon many remote sites and one pair of 7210 with VRRP on the central site.
When the APS terminate their tunnel on the local controller we can authenticate no issue
Whent he APS fail over to the Master controller(we are simulating that the local controller is failing) the users cannot authenticate anymore.
-The APS are using LACP Stripping(its configured on the local controller and also i configured it on the mater controller) i can see the s of Stripping mode on the local controller but i cannot see it on the master controller when they fail over to it(dont know if thats okay)
-I tried creating a WPA2 Preshared key and i cannot even authenticate to it( the password im using is easy "12345678" for testing purpuse i even copy and pasted it and it saying my password its incorrect but i know its correct...
So i dont know whats wrong.
I did the AAA test on all the controllers, and in every controller works fine... it says authentication is succesful, so its not the raidus server.
On the radius server when im trying to authenticate users of the APS which are terminating on the master controller when they fail over when i try to authenticate i cannot see any event on the event viewer ont he radius server like if there wasnt any request getting to him.
Ï do see the request coming to the radius server when i try to authenticate with the aaa test of the controllers...
Any ideas???
Cheers
Carlos
