Authentication Order
  • 1.  Authentication Order
    Posted Jul 19, 2012 10:30 AM
    With Aruba OS 5.0.4.7, is it possible to keep the local default "admin" account enabled but only used as last resort when the specified tacacs server group fails?
    ckc
  • 2.  RE: Authentication Order
    Posted Jul 19, 2012 11:20 AM
    Depending on what you are looking to achieve, have a look at the following command:
    mgmt-user localauth-disable
    This should disable local authentication (for example "admin"), if the RADIUS/TACACS server is responding.  If the server does not respond, the local account can be used.
    If you just want to use both RADIUS/TACACS and local accounts (admin), leave the setting as enabled.
  • 3.  RE: Authentication Order
    Posted Jul 19, 2012 12:09 PM
    I want to ensure everyone is logging in with their tacacs account instead of using the admin account which is enabled by default. As a backup, in case the tacacs server group is not reachable, I still want the default admin account available.
    So to confirm, if I disable the admin account with "mgmt-user localauth-disable", if tacacs fails, the admin account will still work right? I'm on AOS 5.0.4.7
    ckc
  • 4.  RE: Authentication Order
    Posted Jul 19, 2012 05:15 PM
    Yes this is correct (and it is for all local admin accounts, not just "admin").   Please see the results below:
    Authentication attempt by "admin" when RADIUS is online:
    authmgr[1547]: <124004> <DBUG> |authmgr| aal_authenticate user:admin vpnflags:0
    authmgr[1547]: <124004> <DBUG> |authmgr| unknown user=x.x.x.x, method=Management
    authmgr[1547]: <124004> <DBUG> |authmgr| aal_authenticate server_group:default
    authmgr[1547]: <124004> <DBUG> |authmgr| Select server for method=Management, user=admin, essid=<>, server-group=radius-group, last_srv <>
    authmgr[1547]: <124004> <DBUG> |authmgr| server=radius-server, ena=1, ins=1 (1)
    authmgr[1547]: <124038> <INFO> |authmgr| Selected server radius-server for method=Management; user=admin, essid=<>, domain=<>, server-group=radius-group
    authmgr[1547]: <124064> <NOTI> |authmgr| Administrative User Authentication Failed: username=admin IP=x.x.x.x auth server=radius-server
    authmgr[1547]: <124003> <INFO> |authmgr| Authentication result=Authentication failed(1), method=Management, server=radius-server, user=x.x.x.x
    authmgr[1547]: <124004> <DBUG> |authmgr| Auth server 'radius-server' response=1
    aaa[1460]: <125027> <DBUG> |aaa| mgmt-auth: admin, failure, , 0
    aaa[1460]: <125059> <NOTI> |aaa| Since user 'admin' authentication is rejected by authentication server, the user will not be given any access
    Authentication attempt by "admin" when RADIUS is not responding:
    authmgr[1547]: <124066> <INFO> |authmgr| Administrative User Authentication Successful: username=admin IP=x.x.x.xauth server=radius-server
    authmgr[1547]: <124003> <INFO> |authmgr| Authentication result=AAA server timeout(2), method=Management, server=radius-server, user=x.x.x.x
    authmgr[1547]: <124004> <DBUG> |authmgr| Auth server 'radius-server' response=2
    authmgr[1547]: <124014> <NOTI> |authmgr| Taking Server radius-server out of service for 10 mins
    authmgr[1547]: <124004> <DBUG> |authmgr| Select server for method=Management, user=admin, essid=<>, server-group=radius-group, last_srv radius-server
    authmgr[1547]: <124038> <INFO> |authmgr| Selected server <> for method=Management; user=admin, essid=<>, domain=<>, server-group=radius-group
    authmgr[1547]: <124004> <DBUG> |authmgr| Timed Out to N/A
    aaa[1460]: <125024> <NOTI> |aaa| Authentication Succeeded for User admin, Logged in from x.x.x.xport 53416, Connecting to x.x.x.x port 4343 connection type HTTPS
  • 5.  RE: Authentication Order
    Posted Jul 20, 2012 02:34 AM
    Thank you.
    ckc
