last person joined: 7 hours ago
Authentication server rules
  • 1.  Authentication server rules
    Posted Nov 20, 2019 01:58 PM
    we use server rules that flow from a NAC server for authentication. the rules look like this
    filter-id equals aruba:version=1:policy=computer string set role computer
    my question is : if the set role value "computer" is not a role available in the Aruba mobility master  what is the default role? would it be guest?
    thank you
  • 2.  RE: Authentication server rules
    Posted Nov 21, 2019 04:11 AM
    If a role does not exist on a controller (or responding section in the MM device tree), for 802.1X authentication the 802.1X default role is applied, similar for MAC auth, and if no authentication happens (or auth fails and authentication fail-through is enabled) the initial role is applied. Each of these can be configured in the AAA profile:
    Recommended is to return a role (or derive, as you do) during the authentication.
