Developer
authentication working with client credentials but not with username + password credentials
  • 1.  authentication working with client credentials but not with username + password credentials
    Posted Feb 10, 2020 03:14 AM
    I have a guest account to access the ClearPass API clients and REST API. So let's say my guest credentials are
    username = myGuestUsername
    password = myGuestPassword
    with the following settings
    When calling the REST API via
    https://clearpass.company.com:443/api/oauth​
    with my client credentials (changed grant type)
    "grant_type": "client_credentials",
    "client_id": "myAPIClientID",
    "client_secret": "theGeneratedAPIClientSecret"
    I get a valid access token. When I change the grant type to username and password and call the REST API with the body
    "grant_type": "password",
    "username": "myGuestUsername",
    "password": "myGuestPassword"
    I get a 401 response
      "type": "http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html",
      "title": "invalid_grant",
      "status": 401,
      "detail": "Invalid username and password combination"
    I think using the guest credentials is not correct. Which credentials are correct? Is it possible to generate a username and password for the API client?
    I can access the API with the client credentials but other users might not have access to the client secret so I want them to log in with user credentials.
  • 2.  RE: authentication working with client credentials but not with username + password credentials
    MVP GURU
    Posted Feb 10, 2020 03:41 AM
    Do you have Add the Oauth2 API services ?
  • 3.  RE: authentication working with client credentials but not with username + password credentials
    Posted Feb 10, 2020 07:21 AM
    Hey,
    would you mind telling me where I can look it up?
    I'm just using ClearPass as a registered guest.
  • 4.  RE: authentication working with client credentials but not with username + password credentials
    MVP GURU
    Posted Feb 10, 2020 07:56 AM
    on Configuration => Services, you need a Oauth2 service
  • 5.  RE: authentication working with client credentials but not with username + password credentials
    Posted Feb 13, 2020 05:45 AM
    Thanks but unfortunately I can't find it. I will ask for more permissions and reply later
