Looks like a misconfiguration on the device or on your service/policies. Reason can be close to anything with this limited amount of information. Device does not authenticate with a client certificate (EAP-TLS/TEAP), where the service expects that to check the device in Intune, but that in itself is no reason to not authenticate.
May be good to work with your Aruba partner or Aruba TAC to check design, configuration, logs, etc.
Original Message:
Sent: Jul 23, 2024 09:33 AM
Subject: Authetication fail with clearpass- iOS
When iOS device trying to authenticate with clearpass via wifi ,get below error message. What could be the reason. ?
2024-07-23 15:10:19,755 | [HttpModule-ThreadPool-16-0x7f6ffd0d0700 r=R00049aea-06-669fabbb h=142] WARN Util.ParameterizedString - getReplacedStrings: Failed to replace parameString =%{Certificate:Subject-CN}, error=No values for param=Certificate:Subject-CN | |
2024-07-23 15:10:19,755 | [HttpModule-ThreadPool-16-0x7f6ffd0d0700 r=R00049aea-06-669fabbb h=142] ERROR Http.HttpAutzSession - queryAutzAttributes: Failed to construct path from %{Certificate:Subject-CN} | |
2024-07-23 15:10:19,755 | 2024-07-23 15:10:19,758 | [HttpModule-ThreadPool-14-0x7f6ffd4d2700 r=R00049aea-06-669fabbb h=140] WARN Util.ParameterizedString - getReplacedStrings: Failed to replace parameString =%{Certificate:Subject-CN}, error=No values for param=Certificate:Subject-CN |
| 2024-07-23 15:10:19,758 | [HttpModule-ThreadPool-14-0x7f6ffd4d2700 r=R00049aea-06-669fabbb h=140] ERROR Http.HttpAutzSession - queryAutzAttributes: Failed to construct path from %{Certificate:Subject-CN} |
| 2024-07-23 15:10:19,758 | [HttpModule-ThreadPool-14-0x7f6ffd4d2700 r=R00049aea-06-669fabbb h=140] ERROR Http.HttpAutzSession - Failed to get value for attributes=Intune Device Name, Intune ID, Intune User ID] |
2024-07-23 15:10:19,769 | [RequestHandler-1-0x7f6f7e3f4700 r=R00049aea-06-669fabbb h=5745290 c=R00049aea-06-669fabbb] WARN Core.PETaskPostAuthEnfProfileBuilder - handleHttpResponseEv: Fetching Radius attributes from battery failed, errMsg= |
2024-07-23 15:10:19,769 | [RequestHandler-1-0x7f6f7e3f4700 r=R00049aea-06-669fabbb h=5745290 c=R00049aea-06-669fabbb] INFO Core.PETaskPostAuthEnfProfileBuilder - getApplicableProfiles: No Post auth enforcement profiles applicable for this device |
2024-07-23 15:10:19,769 | [RequestHandler-1-0x7f6f7e3f4700 r=R00049aea-06-669fabbb h=5745287 c=R00049aea-06-669fabbb] WARN Core.PETaskRadiusCoAEnfProfileBuilder - handleHttpResponseEv: Fetching Radius attributes from battery failed, errMsg= |
