authorization from Static host lists
  • 1.  authorization from Static host lists
    Posted May 18, 2023 07:24 AM
    hi Airheads,
    i want to use a static host list as an authorization source NOT authentication.
    So in other words if MAC address belongs to a static host list called "DENY-ACCESS"  then take appropriate action.
    However i can't see this is an option in enforcement.
    Any ideas ?
    Pete
  • 2.  RE: authorization from Static host lists
    MVP GURU
    Posted May 18, 2023 07:34 AM
    This is how you will need to set it up in role mapping:
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: authorization from Static host lists
    Posted May 18, 2023 10:04 AM
    thanks Dustin,
    catches me out sometimes ,
    really appreciate your response.
    cheers
    Pete
