Hi.
Is there a way to automatically save the config on a tftp server on the Aruba switches just like the Cisco ones?
Cisco uses the archive command to save automatically everytime the config gets saved.
Thank you
There is no command like the archive command, unfortunately.
hi, maybe you already know this but you can use jobs:
job testBackup-runningconfig at 20:00 config-save "copy run tftp 10.0.0.1 Backup-switchname.txt"
Maybe you find this helpfull.
