Wired Intelligent Edge
Auto configuration upon Aruba AP detection - 2540
  • 1.  Auto configuration upon Aruba AP detection - 2540
    Posted Jun 13, 2018 09:56 AM
    Hi All,
    Does anyone have a list of the elements of auto config that are supported by the 2540? The feature was release in FW16.01 which i think was before 2540 so it isnt mentioned like others that dont support certain elements like egress rate limit.
  • 2.  RE: Auto configuration upon Aruba AP detection - 2540
    Posted Jun 13, 2018 10:50 AM
    Greetings!
    Here are the specific parameters you can configure as part of a device profile (including the default AP profile) on the 2540:
     allow-jumbo-frames    Configure jumbo frame support
    for the device port. cos Configure the Class of Service (CoS)
    priority for traffic from the device. egress-bandwidth Configure egress maximum bandwidth
    for the device port. ingress-bandwidth Configure ingress maximum bandwidth
    for the device port. poe-max-power Configure the maximum PoE power for
    the device port. poe-priority Configure the PoE priority for the
    device port. speed-duplex Configure the speed and duplex for the
    device port. tagged-vlan Configure this port as a tagged member
    of the specified VLANs. untagged-vlan Configure this port as an untagged
    member of specified VLAN.
