Auto-generated anonymous account for web login
  • 1.  Auto-generated anonymous account for web login
    Posted Nov 02, 2016 11:21 AM
    How do I create another auto-generated anonymous account in ClearPass?
    Earlier this year, a support tech helped me create a login page that just required the clients to click a check box.  It used a hard coded login.  I am trying to create another similar page, and need a new login, but when I go to create the account in ClearPass, it will not create all the "variables" needed for the Web Page to work.
    The login the tech created has "Auto-generated anonymous account for web login:" in the description.
    Jason...
  • 2.  RE: Auto-generated anonymous account for web login
    Posted Nov 02, 2016 11:29 AM
    Inside the web-login itself, it will ask you if you want to create one when
    you select Auto-generated anonymous from the drop down.
  • 3.  RE: Auto-generated anonymous account for web login
    Posted Nov 02, 2016 11:33 AM
    Much thanks.  That is what I was missing.   I was trying to manually create the account and was running into several problems.
    Thanks, again.
    Jason...
