Auto Send SMTP Checkbox on Guest Self-Registration
  • 1.  Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 02, 2015 03:31 PM
    Hey,
    CPPM Ver: 6.4.2.30915
    I am have been playing around with our guest portal trying to make a little more user friendly. I was experimenting with the option "Auto-send guest receipts by email with a special field set".
    I was testing the functionality with a checkbox with the default field "auto_send_smtp".
    I had it working. But since upgrading to the latest version of CPPM it appears to have stopped working with a checkbox.
    I have also tested with a radio button and am in the process of testing with a textbox.
    I tried changing the Guest Self-Registration settings to "Always auto-send guest receipts by email" and this worked. I was able to receive the receipt on the personal email address I was using to do my tests.
    Just curious if some functionality changed in the latest version of CPPM? Or is there maybe a recommended way of using this functionality?
    Thank you,
    Cheers
  • 2.  RE: Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 02, 2015 03:50 PM
    bourne,
    Have you tried it like below?  (The rank may differ on your setup).
    6.3.1 changed how that field is evaluated.  Please try the one below.
  • 3.  RE: Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 02, 2015 04:15 PM
    Hey,
    I just tried changing to the settings you have. Although I used the field name "auto_send_smtp". I see the option though for "auto_send_sms", should I be using that even though I want to send an email?
    At any rate, testing with the settings shown in your screenshot (but with auto_send_smtp), I am still not receiving the email.
    Guest Self-Registration portal settings
    Form hidden field settings
    Form setting with Checkbox
    I must be configuring something else incorrectly.
    Thank you,
    Cheers
  • 4.  RE: Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 02, 2015 04:21 PM
    Please try it like below:
  • 5.  RE: Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 02, 2015 04:37 PM
    It looks like the field is defaulted to the values you have in your screenshot.
    I didn't modify the values shown in my screenshot.
  • 6.  RE: Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 02, 2015 04:50 PM
    On a side note I tried the option "Display a link enabling a guest receipt via email".
    Once I authorized the account  (sponsored) I received the link and by clicking this link I received the email to my personal email account.
  • 7.  RE: Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 02, 2015 04:52 PM
    If you have the field on the right form it should work. Please have TAC take a look.
  • 8.  RE: Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 02, 2015 04:58 PM
    Will do.
    Thanks for your support!
    Cheers
  • 9.  RE: Auto Send SMTP Checkbox on Guest Self-Registration
    Posted Jan 09, 2015 03:58 PM
    Opened a case today.
    Will report findings.
    Cheers
