Auto Sign-On with ClearPass and ADFS
  • 1.  Auto Sign-On with ClearPass and ADFS
    Posted Feb 26, 2018 09:50 AM
    Hello everyone,
    A custumer wants to do ASO with ClearPass and ADFS.
    Example : a employee goes to a captive portal and logs in. Then, when he goes to an web application ASO compatible (SharePoint for example), he's automatically logged in.
    I read the technote about SAML Configuration, but i'm not sure to understand how it works. I've never worked on that.
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=24992
    If i'm right, ClearPass would be the Service Provider (SP) and ADFS would be the Identity Provider (IdP).  After a succesful 802.1X authentication, un token is generated by ClearPass and sent to the controller.
    When the user goes to the application, he is redirected to the IdP URL to do a SAML request. The controller intercepts the request and inserts the token and forward it to the SAML IdP.
    Then the IdP checks the token. If it's valid, it sends a SAML assertion in the response to the user.
    My question is : how the IdP can check the validity of the token ?
    Thank you for your help
  • 2.  RE: Auto Sign-On with ClearPass and ADFS
    Posted Feb 26, 2018 09:53 AM
    For ASO, ClearPass is both the IdP and SP and you’d need to use SAML chaining to use a secondary IdP.
  • 3.  RE: Auto Sign-On with ClearPass and ADFS
    Posted Feb 26, 2018 10:39 AM
    Thank's for your quick reply !
    Is there any documentation which can help to understand how to implement it ?
  • 4.  RE: Auto Sign-On with ClearPass and ADFS
    Posted Feb 26, 2018 10:48 AM
    Unfortunately we don’t have documentation for every identity provider. There are too many of them.
  • 5.  RE: Auto Sign-On with ClearPass and ADFS
    Posted Feb 27, 2018 02:49 AM
    Hi Tim,
    I'm interested in this subject too.
    Can you just explain the SAML chaining part?
    The idea would be to chain authentication request from Clearpass to ADFS? would it be done through a service?
    I found your doc on Cloud Identity providers, would it be the same kind of process?
