Automate guest portal password change
  • 1.  Automate guest portal password change
    Posted Jul 16, 2018 10:51 AM
    We have recently started using Airwave for managing our Aruba IAP's and would like to automate changing our guest SSID password weekly. We have found a place to change this in the Airwave CLI but are getting an error when we try to apply it related to applying it through the Airwave console vs. the VC.
    Is there a way to automate the password change through Airwave?
    Also, if there is not, should we consider managing the IAP's through the VC and just use Airwave for monitoring? What Airwave features would we lose by doing so?
