automatic assigning Voice VLAN on ARUBA 2530
  • 1.  automatic assigning Voice VLAN on ARUBA 2530
    Posted Aug 17, 2018 01:59 AM
    i am looking for a solution to automatically assign an IPPhone the Voice VLAN of an Aruba 2530 Series Switch like with CISCO in using the Radius attribute "device-traffic-class=voice".
    I am already able to assign it using the VLAN ID directly, the VLAN Name or a Device Attribute.
    Any idea if this is possible with Aruba 2530 series Switches?
    I am open for any idea and hint :)
    Thank you very much for reading and your time
    #2530
  • 2.  RE: automatic assigning Voice VLAN on ARUBA 2530
    MVP
    Posted Aug 21, 2018 12:53 PM
    Do you want to assign it using an external auth server or by using something like lldp or dhcp snooping on the switch?
  • 3.  RE: automatic assigning Voice VLAN on ARUBA 2530
    Posted Aug 22, 2018 01:47 AM
    Hi Michael,
    i want to use ClearPass to assign it.
    I would like to use sort of a radius attribute that is referring to the voice tag of the Device(Switch/NAD) the radius request is coming from.
    I know it is possible with H3C and Cisco equipment using a vendor specific attribute (AVPair).
    //Martin
  • 4.  RE: automatic assigning Voice VLAN on ARUBA 2530
    Posted Aug 22, 2018 07:29 AM
    Return the role name. Take a look at the ClearPass Solution Guide for Wired Policy Enforcement.
  • 5.  RE: automatic assigning Voice VLAN on ARUBA 2530
    Posted Aug 24, 2018 03:13 AM
    Hi Tim,
    thank you for your reply. Yes that way it will work on a LAN buil only on 2530 Switches. I was not exact in my question as we do run a Network consisting also of older Switch models not beeing able to us use DURs.
    Any additional idea?
