Ok, I'm posting this just for other people to use.
Caveats:
- It's ugly.
- It's complicated.
- It works.
Things you will need:
- A linux server ready to receive the backups.
- (Optional) A subversion repository ready to go.
- A user that can log in on both your Aruba devices and your linux server. This might be an actual LDAP user, or just two local users with the same name and password.
- Successfully connected to all the Aruba controllers from the linux box, using that local user. (The script is not smart enough to understand when it asks if you want to add the host's key.)
- "expect" installed on your linux box.
- If using subversion, have already checked out the aruba folder, so that it's ready to have the svn commands run.
- A basic understanding of how linux, SSH, and shell scripting work, and subversion if you're using it. (Because I don't know how much time I'll have to help anyone troubleshoot this thing.)
So, without further ado, here's the script: getaruba.sh
#!/usr/bin/env bash
# Modified script by Dan Scherck scherckd@evergreen.edu
# Original author Gerrit Tamboer gerrit@gerrit-tamboer.net
#### SETTINGS ####
# What time is it? Dump the date to a variable.
datestamp=`/bin/date`
# Username and PW for scp. Wish we didn't have to hardcode this. Still trying to find a better way.
scp_username=LOCALUSERNAME
scp_pw=LOCALUSERPASSWORD
# Where should I put the data?
backupdir=/home/$scp_username/aruba
backupserver=192.168.5.5
# Define the needed tools by using the "which" command to find their full paths.
scp=`which scp`
expect=`which expect`
ssh=`which ssh`
svn=`which svn`
masterIP=192.168.99.2
local1IP=192.168.99.3
local2IP=192.168.99.4
#### SETTINGS END ####
# Make sure the repo is current.
$svn update $backupdir
# First, we do the backup commands. For some reason chaining this part screws up the rest of the expect if it takes too long, so it's run completely separately.
# The hostnames of the controllers are "Aruba-Master", "Aruba-Local1" and "Aruba-Local2".
# This is important for the expect command to be able to recognize the prompt and send commands / passwords.
## Master controller flash backup.
$expect -c "
set timeout 10
spawn $ssh $scp_username@$masterIP
expect -re \"ssword.*\"
send \"$scp_pw\r\"
expect -re \"aster.*\"
send \"backup flash\r\"
send \"exit\r\"
interact
## Local1 flash backup
$expect -c "
set timeout 10
spawn $ssh $scp_username@$local1IP
send \"$scp_pw\r\"
expect -re \"ocal.*\"
send \"exit\r\"
interact
## Local2 flash backup
$expect -c "
set timeout 10
spawn $ssh $scp_username@$local2IP
send \"$scp_pw\r\"
send \"exit\r\"
interact
# End Backup section.
# Start the actual copy operations.
# Aruba_Master
## This whole section is the expect command.
expect -c "
set timeout 10
send \"$scp_pw\r\"
send \"copy flash: default.cfg scp: $backupserver $scp_username /home/$scp_username/aruba/Aruba_Master.txt\r\"
send \"$scp_pw\r\"
send \"export gap-db ap-database\r\"
send \"copy flash: ap-database scp: $backupserver $scp_username /home/$scp_username/aruba/Aruba_Master_ap-database.txt\r\"
send \"$scp_pw\r\"
send \"copy flash: flashbackup.tar.gz scp: $backupserver $scp_username aruba/Aruba_Master_flash_backup.tar.gz\r\"
send \"$scp_pw\r\"
send \"exit\r\"
interact
# End the expect command.
# Aruba_Local1
expect -c "
set timeout 10
send \"$scp_pw\r\"
send \"copy flash: default.cfg scp: $backupserver $scp_username /home/$scp_username/aruba/Aruba_Local1.txt\r\"
send \"$scp_pw\r\"
send \"copy flash: flashbackup.tar.gz scp: $backupserver $scp_username aruba/Aruba_Local1_flash_backup.tar.gz\r\"
send \"$scp_pw\r\"
send \"exit\r\"
interact
expect -c "
set timeout 10
send \"$scp_pw\r\"
send \"copy flash: default.cfg scp: $backupserver $scp_username /home/$scp_username/aruba/Aruba_Local2.txt\r\"
send \"$scp_pw\r\"
send \"copy flash: flashbackup.tar.gz scp: $backupserver $scp_username aruba/Aruba_Local2_flash_backup.tar.gz\r\"
send \"$scp_pw\r\"
send \"exit\r\"
interact
# Now update and push the new configs to the subversion repo and do some logging.
# Some of the logging may be reduced once the script is working properly.
echo Now starting logging and commit to subversion.
echo $datestamp > /home/$scp_username/current.log
$svn add $backupdir/* >> /home/$scp_username/current.log
$svn status $backupdir > /home/$scp_username/changelist.txt
$svn commit -m "Automatic backup from script" $backupdir >> /home/$scp_username/current.log
echo Backup Operation Completed. >> /home/$scp_username/current.log
cat /home/$scp_username/current.log >> /home/$scp_username/backups.log
