Wired Intelligent Edge
Automatically backup config to scp or tftp when “wr me”
  • 1.  Automatically backup config to scp or tftp when “wr me”
    Posted Aug 02, 2018 08:11 PM
    In Cisco, I can automatically backup config using scp or tftp to other location every time I issue “wr me”
    How to achieve the same in other brand?
    CISCO:
    archive
    path scp://root:eve@10.0.10.70/$h
    write-memory
    HP:
  • 2.  RE: Automatically backup config to scp or tftp when “wr me”
    Posted Aug 06, 2018 10:59 AM
    Not sure if this is possible. Until now I didn't saw this. there are multiple ways in manually making backup's and upload them via SFTP / FTP in single commands. There is also option to restore these backups without reboot. In order to achieve similar process like your I see a lot of organizations enable the following snmp trap:
    snmp-server enable traps startup-config-change
    when the management system than receives this trap it automatically makes backup. Maybe this will also work for you.
    Regard, Dobias
  • 3.  RE: Automatically backup config to scp or tftp when “wr me”
    Posted May 27, 2019 05:37 AM
    in Juniper I tried below commands to auto rollack of config.
    [edit system archival configuration]
    archive-sites {
    ftp://username<:password>@host-address<:port>/url-path;
    scp://username<:password>@host-address<:port>/url-path;
    transfer-interval interval;
    transfer-on-commit;
  • 4.  RE: Automatically backup config to scp or tftp when “wr me”
    MVP GURU
    Posted May 27, 2019 07:06 AM
    There is also
    auto-tfp command too ?
  • 5.  RE: Automatically backup config to scp or tftp when “wr me”
    Posted May 27, 2019 10:08 AM
    switch(config)# crypto key generate ssh
    switch(config)# ip ssh filetransfer
    TFTP and auto-TFTP are now disabled because they cannot be secured with SSH. TFTP can be reenabled with the 'tftp' command.
    auto-tftp no longer enabled by default because not secure
  • 6.  RE: Automatically backup config to scp or tftp when “wr me”
    Posted May 28, 2019 04:48 AM
    you should try creating an alias with the commands you need.
    alias new-wrmem "wr mem
    copy running sftp lala@x.x.x.x
    password"
    I don't believe you can SCP directly from a switch though.
    Aarón
